Vallejo primer damage
    May 2020
Posted by Hutch6390 on Sunday, September 13, 2020 3:50 PM
I've primed & painted a sub-assembly (conning tower of a 1/144 U-Boat) & then found a seam I could have sworn I'd closed up, along with some sanding scratches I've obviously forgotten to polish out.  Then I've tried to gently sand down the affected area, to repair the damage, but the Vallejo polyurethane primer has torn & peeled back, making it much worse than it was.  It's in a prominent place so I can't just leave it & hope it won't be noticed - it's for Glamdring's 50 Shades of Grey GB, so I'll be incriminated by the photographic evidence!
Does anyone know of a fix for this, or do I have to try to strip the whole lot off and start again?  I've only used this primer a couple of times & hadn't needed to sand it back up until now.  I don't think I'll be using it again!  Any advice would be most welcome.
Vell, Zaphod's just zis guy, you know?
TakkaTakkaTakkaTakkaTakkaTakka
Posted by Tojo72 on Sunday, September 13, 2020 4:13 PM
Vallejo primer does not sand well at all,may have to clean up and start again
    May 2020
Posted by Hutch6390 on Sunday, September 13, 2020 4:40 PM
I fear you may be right.  It's probably because I haven't sacrificed any parts to the Carpet Monster lately.  Still, if anyone has any bright ideas, I'd like to hear from them.
    November 2018
Posted by oldermodelguy on Sunday, September 13, 2020 5:20 PM
If there is any chance of feather sanding this stuff it will be after 24 hour dry time with fine paper... But basically it's a non sanding primer surfacer.
    July 2013
Posted by modelmaker66 on Monday, September 14, 2020 12:25 AM
You can clean up the affecred area with rubbung alcohol and a q tip. It will strip only what you want on the plastic. and repair and re prime. This is excellent primer. It needs a couple days to cure before sanding then it is fine. I hit my work with a hair dryer when I use it and it is is great in a day. Hard as nails. All polyurthane primers including stynlrez are the same. I love it, just dry it down with a hair dryer, or let it set for a couple days or remove the area with rubbing alcohol. Let us know what you do and how it works for you please.
    April 2004
Posted by Jon_a_its on Monday, September 14, 2020 3:32 AM
modelmaker66
You can clean up the affecred area with rubung alcohol and a q tip..... It needs a couple days to cure before sanding then
.... All polyurthane primers including stynlrez are the same. ...
Modelmaker66.... Not Quite StyNylRes, behaves like a primer should, Prep surface, & it will spray well, self-level, stick, sand, feather & stay where it's put.
Vallejo POLYEURETHANE primers... not so much! With the Exception of the GERMAN RAL colours, (used only as top coat) I've binned my VJ primer as not worth the effort.
VJ CAN be sanded, if 'hardened' a little with 10% of Future, & left for at least 3-4 days, but it is very picky with surface prep, or it peels off in sheets.
Clean up your seams with IPA/Rubbing alcohol, then fill & prime with StyNylRes, a notably better product.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    November 2018
Posted by oldermodelguy on Monday, September 14, 2020 6:24 AM
Jon_a_its
modelmaker66
Hmm, I've had times where cleaning up with alcohol before spraying Stynylrez has caused a fish eye effect in the primer. If it hasn't happened to you yet, start looking a bit closer, I'm not the only one who has observed this.. I changed to odorless mineral spirits instead for the final wipe down of model parts. I agree Styn is superior to Vallejo primer in that it dries hard much faster and sands decent. But I think MM66 has a point about force drying Vallejo with heat. That probably does quicken and improve the bond. I trust his take and  I have no Vallejo in stock anyway. I switched to Stynylrez as my main primer maybe 3 years ago now.
    May 2020
Posted by Hutch6390 on Monday, September 14, 2020 2:13 PM
modelmaker66
I'll give it a try, thanks for the tip.
modelmaker66
I primed on Friday morning, painted on Saturday afternoon, the model was in a warm, dry room, easlily enough time (I thought!) to dry.  Perhaps not...
OMG, Jon_a_it, I also appreciate your advice.  I'm going to try the IPA & see what happens - isn't this exciting?  I'll post my results here.
Thanks again, everyone.
    November 2018
Posted by oldermodelguy on Monday, September 14, 2020 3:02 PM
Hutch6390
modelmaker66
modelmaker66
Just to be clear, where I mentioned I stopped with ipa was for final wipe down of bare pastic parts before priming Stynylez. Just so there is no confusion.
    May 2020
Posted by Hutch6390 on Tuesday, September 15, 2020 4:49 PM
Bearing in mind the advice kindly given about the length of time needed for this stuff to cure, I came up with a plan.  I let the model sit drying until today, then very carefully cleaned off all the "loose" bits of primer & paint in the damaged area, leaving the hole in the primer & the bare plastic underneath.  I used Perfect Plastic Putty (in tiny amounts) smoothed with a wet cotton bud to fix the seam & scratches.  When that dried I used micromesh to smooth it & to feather the edges of the hole in the primer.  Then, to seal those edges, I sprayed a very light layer of the (same!) primer & filled the "hole" with more, applied with a small brush.
I'm going to leave it for 3 or 4 days (to dry!) & cut it back to where I want it, again using micromesh, then repaint.  I'm pretty sure it'll work - what a flippin' saga!
Thank you again for the benefit of your knowledge, much appreciated!
