I keep my paints inside an unused unplugged fridge in the garage. For more than 8 weeks I've been smelling a paint smell in it. I didn't see any leaks. One old but unopened Testors One Coat Lacquer spray can had some sticky thick yellow substance on the bottom so I thought it was rubber glue from the paper label that is melting off. I had this spray can for maybe almost tens years. I thought it was my two new Rust-Oleum spray cans so took those out. I put a piece of cardboard under the spray can with the "melting rubber glue".
Today I discovered that the Testors One-Coat Lacquer had somehow all leaked out. The cardboard was soaked and glued to the surface and the paint substance is thick and sticky. The can felt empty but it was never opened.
Have you ever experienced this ? Is the inside of my fridge that hot? I noticed my fridge actually insulates the cold even on hot days it is cool inside. Or is this can defective ?
