Sparmax O-ring issues
    May 2011
Posted by dazzjazz on Sunday, November 8, 2020 2:02 AM
Hi,
I recently replaced nozzles in my 2 Sparmax airbrushes. Unfortunately, with very little use, both O-rings have disintegrated and fallen away.
While I've contact the local distributor (awaiting reply), I'm wondering if anyone has had a similar issue? I sparingly use Tamiya airbrush cleaner.
thanks
Darren
    May 2011
Posted by dazzjazz on Wednesday, November 11, 2020 9:37 PM
Sparmax have told me to keep the Tamiya Airbrush cleaner away from the o-rings.
Such a bummer - can't replace the o-rings myself and now I'm up for two new nozzles.
Anyone had a similar experience?
Darren
    June 2010
Posted by montague on Thursday, November 12, 2020 2:15 AM
dazzjazz
Darren
Sounds like a good time to try another brand.
    August 2005
Posted by Phil_H on Thursday, November 12, 2020 2:37 AM
dazzjazz
What sort of paint are you cleaning out of your airbrush? If you're using Tamiya acrylics, you don't need to us anything stronger (or more expensive) than metho.
Yikes. I just saw the price of Tamiya airbrush cleaner in Australia. Wow, it must be distilled from unicorn tears or something.
    April 2004
Posted by Jon_a_its on Thursday, November 12, 2020 4:35 AM
I use X20a or IPA or Medea airbrush cleaner (because I have a lot of it) to clean the airbrush.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    May 2011
Posted by dazzjazz on Thursday, November 12, 2020 3:09 PM
Thanks for the advice about metho. I'm only using acrylics.
I have thought I should ditch the Sparmax, but with two of them, I've made a significant investment. I might try to call the distributor today. Doesn't seem right that the o-rings last just hours.
    November 2018
Posted by oldermodelguy on Thursday, November 12, 2020 6:35 PM
My Ganzton airbrush O rings are in tough shape too, I just seal it up with bees wax on assembly and they haven't ripped any further. Even if they did and I tossed them the bees wax would probably work fine. In some of the airbrush tune up tips for Chinese airbrushes they suggest doing that.
If you knew the size you could probably get some tougher O rings in nitrile, neoprene or silicone online someplace.With my Ganzton I don't use the thing enough to bother personally. I stick with my Badger or Paasche for the most part. I rarely use double action.
