What colour of Tamiya panel wash to use on red oxide coloured model?
    April 2020
Posted by JonR on Tuesday, November 17, 2020 4:55 PM
Hey first time going try weathering and wash on model and I'm airbrushing my model in red oxide and want to know what colour of the tamiya panel wash i will want to get ?
thanks ...
Posted by Tojo72 on Tuesday, November 17, 2020 7:26 PM
Well,what your simulating is dirt stuck in between the pals or in the corners. I would go with burnt umber
    April 2020
Posted by Eaglecash867 on Tuesday, November 17, 2020 7:55 PM
Be careful with the Tamiya Panel Line accent and test it on a spoon or something that you've painted the same color as your model.  I have found that it even starts to attack Tamiya acrylics if its not handled just right.  I'd look around and see if you can get Flory Wash instead.  Very easy to use, and totally safe on any paint because its water based.  Just tried Flory for the first time on my Tamiya F-16 after a near disaster using the Tamiya wash (took my Acrylic clear coat off, and went right after the MM enamel underneath).  With Flory, I had the whole wash and removal done in less than an hour, and not a single trace of paint on the sponge.  It turned out beautifully.  They have all kinds of different colors, including several different brown tones like the burnt umber Tojo suggested.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    June 2010
Posted by montague on Wednesday, November 18, 2020 2:02 AM
Ditto
