Alternative to Testors Dullcote
    December 2017
Posted by WWII_AC on Tuesday, December 15, 2020 4:34 PM
Is there an alternative to Testors Dullcote rattle-can that be airbrushed?
    April 2020
Posted by Eaglecash867 on Tuesday, December 15, 2020 4:48 PM
I'm currently using MRP Super Clear Matt.  It comes in a 30ml bottle and is airbrush ready, straight from the bottle.  Does a better job of knocking the shine off of things than Dullcote does.  I decided to try it because my Dullcote (I have the kind in the bottle for airbrushing) just wasn't getting the paintjob on my F-16 flat enough.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Tojo72 on Tuesday, December 15, 2020 5:49 PM
If you like Testors, they make a bottled dullcote for airbrushing its Lacquer based and easy to use.
I also like the Alclad stuff,lacquer based and dead flat.
If you want acrylic,Vallejo makes a nice matte.
    February 2016
Posted by German Armour on Tuesday, December 15, 2020 6:23 PM
Also, from my research, you could try winsor and newton Galeria Matt varnish.
Here's a link.
https://www.britmodeller.com/forums/index.php?/topic/46166-winsor-newton-galeria-matt-varnish/
 Never give up, never quit, never stop modelling.Idea
    May 2013
Posted by Greg on Tuesday, December 15, 2020 7:27 PM
As much as I swear by good 'ol Testor's Dullcote, far as I'm concerned Alclad Klear Kote Flats are far superior. They airbrush like a dream out of the bottle, and the ALC-314 Flat is the flattest flat I've ever seen.
Though I make sure to keep all 4 in stock, I've always figured one could just have the 311 and 314 and probably mix any degree of flatness in between by mixing.
I have never once had this product line frost up due to operator error, I surely have with many other clear flats.
    May 2006
Posted by Shipwreck on Wednesday, December 16, 2020 8:09 AM
Greg
I have been using Testor's Dullcote over Tamiya acrylics. Do the Alclad flats work over the acrylic paints?
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
Posted by Don Stauffer on Wednesday, December 16, 2020 8:11 AM
I have used both polyurethane and acrylic flat clears from my local hardware store.  Thin them a lot.
    June 2014
Posted by BrandonK on Wednesday, December 16, 2020 9:29 AM
Model Master 4636 Acryl flat clear. Works perfect in the AB.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by gregbale on Wednesday, December 16, 2020 10:45 AM
I used Dullcote quite happily literally for decades. But when I switched to acrylics some years ago, I went through a laundry list of so-called flat or matte finishes without finding one I really liked.
Finally tried Vallejo's 100% acrylic matt varnish, and haven't looked back. Best stuff I've ever used, no contest. (I spray it, but it even brushes quite well in a pinch.)
Thins perfectly with Tamiya X-20A, cleans up easily with plain alcohol. It's tough and highly resistant to incidental handling. And...it can be mixed easily with Future (or whatever they're calling it these days) to any required degree of satin, semi-gloss or near-gloss finish.
Great stuff!
Greg
George Lewis:
    May 2013
Posted by Greg on Wednesday, December 16, 2020 11:11 AM
Shipwreck
Yes, at least I've never had a problem.
That said, I usually lay down my flat clear coats in a much lighter spray then gloss coats, and I've always figured since it is going on a little on the dry side it reduce the chances of damaging anything underneath, but that's just a theory.
    November 2018
Posted by oldermodelguy on Wednesday, December 16, 2020 2:23 PM
I must have left the page and not posted my reply. I had one all typed out earlier today.
Anyway lately I've been using Liquitex matt varnish, seems to do well. I'm out of Dulcoat and we have the varnish here for my wife's ceramics work so figured why not ? I have not shot it over decals though but Liquitex sticks to about anything so I can't imagine that being a problem.
    December 2017
Posted by drumsfield on Thursday, December 17, 2020 6:08 AM
I love the testor stuff but it's a pain to decant it into the brush. I mostly use alclad stuff now. Pricy but worth it for me. I also heard Winsor Newton Work well. Though I've never tried it.
This is what I use.
Alclad Matte Varnish
Posted by Don Stauffer on Thursday, December 17, 2020 9:07 AM
Tojo72
They also have the glosscoat lacquer in bottles.  I thin it one to one with hardware store lacquer thinner.
    February 2007
Posted by Steve1209 on Thursday, December 17, 2020 2:23 PM
I'm currently trying to flatten the finish over a coat of Future I used for decals and washes. I applied Testors Dullcote lacquer from the rattle can, but find the finish still retains a bit of sheen.
I see some recommendations here for Alclad, Vallejo and Testors bottle. Any considered best to go over the Future?
On the bench:
Tamiya Sheridan M551
AFV Club IDF Centurion
    March 2015
Posted by JohnnyK on Thursday, December 17, 2020 7:04 PM
Tamiya makes a flat clear lacquer. I am going to give a rattle can a try tomorow. I'll let yiu know what happens.
Posted by Tojo72 on Friday, December 18, 2020 10:15 AM
Steve1209
All should work if you allow the Future to fully cure.The key with any of these is to use light misting coats don't flood any of them on.
    October 2019
Posted by Tanker-Builder on Friday, December 18, 2020 1:35 PM
Hmmm;
 I don't remember the Brand.I bought a tall bottle( Bigger than Vallejo's ) and it's an acrylic craft paint. No thinner needed except for clean-up. De-natured Alcohol works great as a cleaner
    February 2007
Posted by Steve1209 on Friday, December 18, 2020 1:54 PM
Tojo72
Steve1209
Thanks all for the comments. I'll try some light recoats of Dullcoat. I also have some model master acrylic flat, but haven't tried it yet...
On the bench:
    March 2015
Posted by JohnnyK on Friday, December 18, 2020 2:59 PM
This is Tamiya Clear Flat applied over Tamiya gloss gold. IMHO, the Tamiya Clear Flat has less gloss than Model Master Dullcoat. Both Tamiya paints were via rattle cans.
    October 2015
Posted by M60_ tanker on Friday, December 18, 2020 4:27 PM
Rust-Oleum makes a product called Dead Flat. Basically Dull coat in a large spray paint can. You can find it in the spray paint aisle.
Don't be suprised if Dull Coat goes away.
Nothing is impossible as long as somebody else has to do it.
    November 2008
Posted by plasticjunkie on Saturday, December 19, 2020 8:58 AM
WWII_AC
It also comes in a bottle for airbrushing. Thin with LT and spray away.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Saturday, December 19, 2020 9:29 AM
M60_ tanker
Why?  I don't think the clearcoats were part of the model master line.  Testors is not going away, only the model master enamels.
    March 2015
Posted by JohnnyK on Saturday, December 19, 2020 11:36 AM
The Dullcote is a Testors product and the Gloss Clearcoat is a Model Master product. HUH!!!!  Why???? I would guess that this was a marketing concept.
Posted by Don Stauffer on Sunday, December 20, 2020 8:36 AM
JohnnyK
Wow, I never noticed that!  Never was aware of the "ultra gloss clearcoat."  I always thought the regular gloss coat was glossy enough.  Testors gloss and dull coats still available.  Just bought a can of each.
    December 2017
Posted by WWII_AC on Thursday, December 24, 2020 10:43 AM
Greg
...the ALC-314 Flat is the flattest flat I've ever seen.
You weren't just whistling dixie. I went with this as the alternative and I must say I was very impressed with results!
Now, a follow-up question. After this dries a few days, am I going to be able to use an oil paint (Academy) and enamel paint thinner pin wash for panel lines on top of this ALC-314?
Posted by Wingman_kz on Thursday, December 24, 2020 3:23 PM
The Ultra Gloss is from their line of gloss lacquers for automotive modelers. Don't remember the year they were released but it's been a few. They had some classic colors and some muscle car colors in that line. I remember some comments about how well this paint flowed and how glossy it was. I think "non-yellowing" was a big part of their advertising too. How different it is from Gloss Cote I couldn't say, I mostly used clear fingernail polish at the time.
Posted by Don Stauffer on Friday, December 25, 2020 10:19 AM
The regular Glosscoat is now UV stabilized (non-yellowing).  Not sure when they did that, but it was quite a few years ago.
    April 2020
Posted by Eaglecash867 on Friday, December 25, 2020 8:41 PM
I wonder why they thought a UV stabilized coating was a factor for something that is generally going to be kept indoors.  You could even display your models in a window on your house and they're not going to get any UV.  Heh...well...I guess its a good marketing gimmick. Cool
Posted by Wingman_kz on Monday, December 28, 2020 1:19 PM
Testors or Model Master clear enamels have an amber tint in the bottle. Maybe that had something to do with the yellowing reference. This Ultra gloss is very shiny.  :-)
    May 2013
Posted by Greg on Monday, December 28, 2020 4:13 PM
WWII_AC
I'm very happy that you tried it and more importantly, like it!
WWII_AC
I don't have much experience with pin washes, but I see a couple potential problems. First, I think a pin wash works (flows) better over a gloss surface and second, both the Alclad and enamel thinner are solvent-based so I'd be concerned about the latter attacking the former.
OTOH, if you did a pin wash over gloss, let it set up then spray on the Alclad clear coat, I'm pretty sure you'd be ok.
All that said, if you are confident enough of your techique to apply the pin wash with high precision and not have any overflow, maybe it'd be ok.
Sorry I didn't see your comment and question sooner, and it was nice of you to provide feedback.
