Airbrush practice Medium
    December 2020
Posted by jackinil on Wednesday, January 6, 2021 9:20 AM
Being new to airbrushing,I've read about people  practicing on plastic spoons,scrap plastic,etc. Is an empty plastic milk carton viable for practicing on? I have new Paasche H to try out. Thanks
Posted by Tojo72 on Wednesday, January 6, 2021 9:44 AM
Maybe if you prime it first,but otherwise I don't see it mimicking the surface of styrene plastic
    July 2004
Posted by stikpusher on Wednesday, January 6, 2021 9:51 AM
The best thing to practice on is an old model. An old build from once upon a time makes a super paint test mule.
You can learn to contend with all the challenges of airbrushing a model: shapes, angles, overspray, masking, etc.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February 2016
Posted by lowfly on Wednesday, January 6, 2021 9:57 AM
if you are looking to practice your steady hand with the airbrush i reccomend using a small glass sheet to practice on.  You can paint on it and than scrape the paint off with a razorblade and do it again.
If you are trying different techniques like thinning paints, using different PSI settings and that sort of thing i would reccomend using a paint mule, An old model that you dont care about.
Posted by Tojo72 on Wednesday, January 6, 2021 9:57 AM
Or a cheap garage sale,flea market model if you don't have any old models
    July 2004
Posted by stikpusher on Wednesday, January 6, 2021 10:33 AM
For checking your spray pattern, or the size of lines, a simple piece of plain paper works just fine. Keep it simple.
       - Plankton
LSM
    April 2020
Posted by Eaglecash867 on Wednesday, January 6, 2021 10:52 AM
I use sticky notes for various things while modeling, and checking spray patterns is one of them.  When one gets used up, I just pull it and have a fresh one ready to go.
To the OP, I have a Paasche H also, and I've tried many times to change to something "better", but I just keep coming back to my Paasche H.  You've definitely got a simple, reliable airbrush there.  You'll love it.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Don Stauffer on Thursday, January 7, 2021 8:40 AM
Depends on the type of plastic.  Large milk jugs are polyethylene, which is a bear to get paint to stick to.  I personally like the spoons.
