Hi folks, Im not sure if this is the correct place to ask but I'm trying to paint a battalion insgnia on a model and I'm lost. I've inserted an image of what I'm trying to paint below and I have 3 main questions:
1) How do I sketch out the lines on the model without putting brush to plastic and how do I do it in a way that I can remove the marks without damaging the layers of paint under it. I was thinking pencil but Im not sure if theres a better way of doing it.
2) How do I best paint the thing. I figure I should use a very fine brush but should I use very thinned down paint or use thick paint so that lines do not run. Im not sure if thick paint would make a noticeable layer but I also do not want to have transparent paint lines.
3) How do I make the size of the insignia in scale with the rest of the model? Same goes for the lines
I don't think I will have problems keeping my hand from shaking. I am also concerned that I will regret adding the detail later on.
&psig=AOvVaw3Y4aRThd468hYorz-Cvq2b&ust=1611762710278000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCIis1JD6ue4CFQAAAAAdAAAAABAO)
