Airbrushing thin camouflage lines on armored vehicles?
    October 2020
Posted by rcguy on Monday, February 1, 2021 1:06 PM
Hello,
Is there a specific method to painting thin camouflage lines on armored vehicles?
I just sprayed the tank I recently finishes with some basic camo lines with Tamiya 65 field grey over top of Tamiya dark yellow base and can not seem to get the lines tight for lack of a better word.
I get a lot of overspray on both side of the lines.
I tried reducing the pressure from the air tank and moving the airbrush to different position (closer and further away) but no luck.
Any suggestions would be a huge help
I would post photos but I gave up trying to figure that one out.
Thank you!
Posted by Tojo72 on Monday, February 1, 2021 1:33 PM
Reducing the pressure as low as 8 psi and thinning the paint down to as low as 75-25
Of course,to get better answers,the type airbrush and paint being used would help
    April 2020
Posted by xenon55 on Monday, February 1, 2021 1:39 PM
I'm relatively new back to the hobby (started with it again last Spring/Summer) and I came across using blu-tack on this forum. I tried it for the first time on a Spitfire. I don't have any in process pictures unfortunately. I started out by spraying the grey first, lightly drawing the camo pattern with a pencil, running a blu-tack "snake" near my pencil line on the outside of where the green would be sprayed (so the paint covers the pencil line), then covering the areas that need to stay grey with masking tape. I used Vallejo paints and didn't have a problem with paint lift when removing the blu-tack. I let the grey basecoat cure for at least a week iirc. Also paint from above and not at angle depending on how feathered you want the camo lines. The diameter of the blu-tack "snake" will also play a roll in the feathering. Small diameter tight line. Large diameter more feathering. Here are a few pics to show how it came out for me.
Jay
    October 2020
Posted by rcguy on Monday, February 1, 2021 1:43 PM
I'm using Tamiya acrylics and a Paacshe Talon airbrush. The paint on the airplane above looks great but I'm looking at more of the finer camo lines.
    April 2020
Posted by xenon55 on Monday, February 1, 2021 1:46 PM
Sorry. I didn't realize that you were trying to airbrush thin stripes. Can't help there. I haven't attempted it myself yet.
Jay
Posted by gregbale on Monday, February 1, 2021 2:14 PM
Some airbrushes have interchangeable fine or extra-fine nozzles or adjustable trigger stops to limit airflow. My beloved Badger Anthem has neither -- it's just a matter of thinning and enough practice to get the right 'touch.'
If you're new to spraying those thin lines, practice and experimentation with thinner ratios are your best friends. Practice on an old model, or even something like 3x5 cards. It's important to keep your spray perpendicular to the surface to limit overspray.
With just thinning, air-pressure regulating and 'touch,' I can spray pretty good 1/16" or slightly smaller lines with thinned Tamiya acrylics. But it took a fair amount of practice to get there.
Good luck.
Greg
George Lewis:
    October 2020
Posted by rcguy on Monday, February 1, 2021 3:03 PM
My airbrush came with 3 different nozzles.
I'll try putting the fine one on and thinning the paint down more the the 50/50 I'm using now.
    August 2014
Posted by goldhammer on Monday, February 1, 2021 6:31 PM
On the right track.  Turn down the air to where you are just atomizing paint, move in close, probably a lot closer than you would think.  Since you're using a mix more like water, go easy on the trigger.
As was said above, practice.  The practice pieces can be scrap, for sale signs, plastic spoons, take out containers, etc.  Untreated paper or cardstock will tend to soak up the paint and spread it wider than sprayed.
