Issues with clear coating a certain airbrush paint
    January 2021
Posted by Alterean on Tuesday, February 2, 2021 11:12 PM
I recently got an airbrush, and have started using Createx Colors white airbrush paint for painting white, and US Art Supply and Vallejo air for other colors.
There have been no issues using my various matte clear coats on either of the latter two brands of paint, but with the white I'm seeing issues with it cracking.
https://imgur.com/a/X8zHnoL
At first I thought it was the new clear coat I was trying, since I got them both at the same time, which is just a basic Rustoleum matte coat. I tried Krylon next, with the same issue, then went back to my old Model Master matte coat and again had the same problem.
I don't understand what's causing this, no other paint I've ever used has done this.
Any ideas? Or maybe suggestions for an alternate brand? I like the bottle size and cost of Createx, but it's unuseable if it does this.
The cost for a tiny bottle is why I don't use Vallejo Air, and when I tried out the US Art Supply white it just didn't cover at all.
    April 2004
Posted by Jon_a_its on Wednesday, February 3, 2021 1:19 AM
White is one of the hardest colours to paint.
Looks like your paint may have been too thick, (in order to get coverage, yea I know) and wasn't 100% cured, some brands & colours, even acrylics need to gas out.
I suggest a bath in IsoPropyl Alcohol to wash off, & a used toothbrush to scrub, as sanding will destroy detail.
One of my favourite primers is Tamiya acrylic, thinned with Tamiya Lacquer Thinner (orange top) as this give it bite & covers very well.
Can you get lacquer primers? Tamiya, Hataka, MIG? Auto paint cans?
Alternatives are Badger StyNylRes white (a little thick) or my current favourite MIG-0046 Satin White.
PS my favourite Clear Coat is Windsor & Newton Galeria Mat Satin & Gloss. It's the brand I have FEWEST problems with.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    August 2005
Posted by Phil_H on Wednesday, February 3, 2021 2:13 AM
How long are you leaving the white to dry before clear coating? Assuming that your clear coats are spray cans, they would be quite hot.
I would try leaving the white to dry and cure at least overnight (min 12 hours) and then apply the clear coat using very light mist coats to build it up rather than attempting to cover with a single wet coat (if that's what you're doing).
    November 2018
Posted by oldermodelguy on Wednesday, February 3, 2021 5:44 AM
The thing about Createx is it was originally designed for the T Shirt industry to be applied to fabric. As such it dries pliable. They have their own clear but any of the artist brands varnishes will work well with it too. I think you find it's the different flex rates and expansion and shrinkage over large areas that is cracking your clear coat. So you have a choice, change out your white paint brand or keep what you have and use an artist grade clear, be that Createx, Liquitex, Goldens, WN Galerie etc.......
That said, I use some Liquitex varnishes myself ( probably be a lot less now that my artist wife passed away) and it sprays straight from the bottle fine.
    January 2021
Posted by Alterean on Wednesday, February 3, 2021 8:51 AM
Appreciate all the input.
This white paint had been sitting since Saturday, so I figured 3 days was more than enough time for the paint to fully cure. But I really don't know.
I think I'll get the createx matte top coat and try that first before a new brand of white. I really like how this white covers, which is why it's annoying that it's doing this.
    June 2014
Posted by BrandonK on Wednesday, February 3, 2021 10:13 AM
I use Krylon Color Master Clear over all my Creatix paints. I have had no issues whatsoever.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
