Can I use the standard clear coats ( Future, Vallejo, etc.) over metalic paints? Like Extreme Metal. Or are there special clear coats to use?
Bob D Can I use the standard clear coats ( Future, Vallejo, etc.) over metalic paints? Like Extreme Metal. Or are there special clear coats to use?
Suggest you do a test piece first, then clear coat it with the SAME brand clear, or whatever the mfr recommends.
East Mids Model Club 29th Annual Show 19th MAY 2019
http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Anybody used this stuff: Intermediate Gauzy Agent Shine Enhancer? It is supposed to be the clear coat of choice for the AK Xtreme Metal paint line. If you have, what do you use to clean it out of your airbrush? I haven't been able to find that info anywhere I've searched on the 'net. Thanks for any tips!
Doug
Slidell, LA
This Gauzy product claims it will not affect the metal shine as other clear coats will so I will get a bottle to try it out. Even though I haven’t used this Gauzy products I do believe Lacquer thinner will clean the ab after using it. I use LT to clean everything I spray in my ab, lacquers, enamels and acrylic with no problems.
I got my bottle in. Have not airbrushed it yet, but on a test piece it went down very well with a brush. Self leveled, dried well. Windex removed it, just as with future. I did not try anything else since the windex worked.
