plasticjunkie
Hi Greg. Yes it's water based and I sprayed it about 12 psi, straight from the bottle. Light passes about 2" away till you get coverage. It protected the delicate high shine Alclad against masking tape damage. The Alclad metallic effect is there and I can honestly say there is little if any loss of reflection. I cleaned the ab with a Windex then rinsed with plain water. I followed up with LT to be sure internals were spotless.
Compared to Futue, it levels out and doesn't kill the metallic Alclad effect unlike Future that does. I brush Future because I get orange peel when I spray it. I experimented with a test piece shot with Alclad and sprayed Future over it. No comparison, Gauzy did 100% better job and is most noticeable in person, while a picture doesn't quite capture the full effect.
Thank you for a great rundown, Ernie!
I gave up spraying Future long ago, and though I'm a huge fan of Alclad's solvent-based clears and had high hopes for their water-based clear (Aqua-Clear, I think it is), I never really figured out how to spray it either.
I think I'll order some of the Gauzy right now before I forget, and cart it with me back to the bench when the time comes. A recommendation from you is a very high mark in my book.
I don't have a lot of experience ordering AK products. Any recommendations?
