Can I use a primer as a models main color?
    March 2021
Posted by berd on Wednesday, April 14, 2021 1:20 PM
Like as in i will paint the model in primer and just weather and clear coat over it.
    April 2009
Posted by Cadet Chuck on Wednesday, April 14, 2021 1:52 PM
Yes, I have done this when the primer color is right for the model.  Usually do white, for aircraft undersides.
    August 2005
Posted by EdGrune on Wednesday, April 14, 2021 2:51 PM
Most definately.   Rustoleum Red Primer is my go to for ship hulls.    Vallejo Model Air Gray Primer is often called out for US Ghost Gray.
    November 2018
Posted by oldermodelguy on Wednesday, April 14, 2021 3:34 PM
I use stynylrez black primer quite a bit as a color actually. Depending what primer you're using and what weathering products used, you might just want to put down a quick seal coat. Stynlrez is a sealer too though so I don't bother. I use it for rubber hoses and belts and such and weather the tone I want right over the primer using water clean up oil stains. Or a craft paint wash for that matter. My engine compartment and engines and such are generally primed in black anyway to take aluminum or other metal paints and such.. So ya, have fun !
    January 2021
Posted by PFJN2 on Thursday, April 15, 2021 3:33 PM
Hi,
I also use primer as regular paint on my models too.
    January 2020
Posted by Space Ranger on Friday, April 16, 2021 3:13 AM
Many airliner modelers use Tamiya's Fine White Primer as a basic color for predominantly white color schemes.
Posted by Don Stauffer on Friday, April 16, 2021 7:39 AM
I use red oxide primer for bottoms of all my freshwater models.  Some GL ships use red oxie all the way up to deck, so the primer works up to deck.  Some of these ships even use it on decks and hatches,so I do too.
    October 2019
Posted by Tanker-Builder on Friday, April 16, 2021 8:20 AM
Hi;
     When I build my Tankers, That's what I usually do. Red Oxide on the Bottom and Decks and Black on the hulls and Tamiya White primer on the deckhouses. Then Clear coat everything for weathering and detailing.
