Does future floor gloss crack over time?
    March 2021
Posted by berd on Saturday, April 17, 2021 8:33 PM
I saw some posts on a diffrent site where someone reported that after a few months the future floor gloss started to crack
Thanks
    April 2004
Posted by Jon_a_its on Sunday, April 18, 2021 3:58 AM
Several reasons for this:
It shouldn't as it self levels, as in I dip canopies it it, then (important) wick away the excess by sitting it on lint free tissue for a few moments.
Gloss coat/Future put on too thick.
Finish coat not properly cured, some paints can take weeks.
If the underlying object is flexible (most polythenes) or not properly primed, this can cause the top coat to crack or flake.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    April 2020
Posted by Eaglecash867 on Sunday, April 18, 2021 5:44 AM
I think there are several different formulations of Future out there, because I know lots of people here have never had issues with it.  I, on the other hand, have had it start cracking after only a few weeks when used as a clear coat prior to weathering/decaling.  This was after airbrushing it over fully cured paint (1 week or more of curing time in all cases).  The only way I found to prevent it was to put a lacquer clearcoat over the top of it, which makes me wonder why I wasted the extra time putting the Future on if it can't do the job on its own.  Also haven't found my Future to be of much use for dipping canopies, as it reacts really badly with my Bob Dively Liquid Mask.  I'm in the camp with those who say "Future is for floors".  For me, lacquer clear coats for model bodies, and my Novus polishing kit for canopies have proven to be much better alternatives.  That being said, Future is the absolute best adhesive I have found for small, clear parts and small, flat PE parts where complete clarity after drying is critical.  So, I still use it, just not for what many use it for.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Tojo72 on Sunday, April 18, 2021 6:10 AM
From what your saying  sounds like it can, as you mentioned, some have had that happen to them.
    November 2018
Posted by oldermodelguy on Sunday, April 18, 2021 6:15 AM
The iteration I have is called Pledge Floor Care and I haven't had any issues with it ( I notice it's also no longer on the shelf at my local store). It might be worth noting that I also give my dry times of base coats a boost in a dehydrator at 108f as a general routine.
It's not the only clear I use though.
    July 2008
Posted by jeffpez on Sunday, April 18, 2021 7:13 AM
I've used it for at least a decade and never had any problems, including cracking. That includes using it as a shiny top coat for decals and weathering, coating clear parts and trying to get some shine on my worn out kitchen floor. The last time I bought some (several years ago) I wasn't sure I had the correct product so I unscrewed the cap and gave it a sniff.
Posted by gregbale on Sunday, April 18, 2021 7:14 AM
Never personally had it happen in over two decades of use.
But as many times as its formula may have been 'tweaked' by the manufacturer...and considering the ever-wider variations of chemistry found in modern model-finishing products...I'd almost be surprised if it hadn't happened.
The thing is, I've been working off the same bottle of 'Future' (still called that, then) for maybe as long as ten years, with not a single issue; it may be that when the time comes to replace it, I'll be in for that kind of nasty surprise.
Greg
George Lewis:
