Painting missiles and bombs
    April 2021
Posted by RobCosta on Wednesday, April 21, 2021 11:13 AM
How do you paint rings on missiles/bombs/tanks?
    September 2003
Posted by checkmateking02 on Saturday, April 24, 2021 3:10 PM
It isn't easy and depends on the shape of the bomb or missle.
It's sometimes easiest to make decals.  This works best for a straight wrap-around.  I have used white decal film, painted it and then applied.
For difficult areas, like a ring around the nose, I've tried hand-painting.  Paint the bomb, then coat it with a gloss overcoat.  For this I used enamel/lacquer base paint and clearcoat.  Then paint the ring with a brush, using water based acrylic paint.  Use a damp tooth pick, and clean up the ring.  It didn't work overly well, but the bombs looked OK in the bomb bay.  They are 1/72 scale, and a lot smaller in real life than they appear in the photo.  That tends to minimize the crudity of the paintwork!
In the photo below, I used painted decal stock for the green stripe, and hand-painted the red nose ring.
New Ware makes some paint masks for bombs; available from Hannant's in the UK, and maybe other sources as well.  I haven't tried them.
Good luck!
Posted by keavdog on Saturday, April 24, 2021 3:19 PM
Tamiya vinyl tape is helpful for masking complex curves.  But I'll go decals whenever I can.  I have a set of red and black stripes of various widths.
Thanks,
John
    August 2014
Posted by goldhammer on Saturday, April 24, 2021 4:35 PM
If just needing nose stripe, can dip in the stripe color after painting the body, wick off the excess.  When dry, dip in the body color if needed.
In the pic above, after painting the yellow, dip in red, when dry, redip in yellow to set stripe width.
    January 2020
Posted by wpwar11 on Saturday, April 24, 2021 9:40 PM
Let's say the missle  is grey and the ring is brown.  Paint the area where the ring goes brown.  Cut masking tape the width of the ring.  Wrap the tape around the missle.  Paint the missle grey.
    June 2003
Posted by Jammer on Sunday, April 25, 2021 12:45 PM
Not sure where I first saw it, but the tip I have stashed away for painting rings on bombs was to paint the bomb (or at least the ring area) the ring color.  When it was dry, put a small rubber band like those used on braces where you want the ring.  Paint the bomb the color you are going to use.  When it is dry, remove the rubber band and you should have a good ring in place.
    May 2013
Posted by Greg on Sunday, April 25, 2021 2:46 PM
wpwar11
That's what I do too.
    October 2019
Posted by Tanker-Builder on Sunday, April 25, 2021 4:57 PM
Oh?
Here's what I do. I chuck them in an old hand drill and take the drill and put it in the vise. Then I use a striping brush and slowly totating the handle, Which rotates the Bomb or Missile or Fuel drop tank.
