What color primer would you use under white?
    June 2020
Posted by JimLo on Wednesday, April 28, 2021 8:09 PM
What color primer would you use under white paint? The bare plastic is either white or red. Thanks
Posted by Tojo72 on Wednesday, April 28, 2021 8:49 PM
I would use Tamiya white primer.
    September 2012
Posted by GMorrison on Wednesday, April 28, 2021 11:11 PM
The only concern would be if you can see the coverage of the finish white over the primer white, but a flat white primer followed by a gloss white finish should be workable. Or if flat over flat, just use multiple coats of the same paint.
I like white primer and use it pretty much exclusively except under metallic silver.
I usually mask where the decals will go if those are a kind of regular shape because decals are designed to read as true colors over white. Same with translucent paints.
Bill
    June 2020
Posted by JimLo on Thursday, April 29, 2021 12:03 AM
Thanks. I agree that it might be hard to see the white over white. But anything darker won't help the final white finish either ? Ok
Posted by Bish on Thursday, April 29, 2021 4:03 AM
White or grey depending on the subject and what sort of finish i wanted.
    May 2009
Posted by Pawel on Thursday, April 29, 2021 9:28 AM
Hello!
I usually use one layer of grey primer and white primer over that. Tamiya white primer is so nice that I seldom if ever overcoat it.
Good luck with your builds and have a nice day
Paweł
www.vietnam.net.pl
