Is this a good respirator?
    January 2021
Posted by Teenage Modeler on Monday, May 10, 2021 2:10 PM
So my dad purchased this respirator, and I was wondering if it is good for models.
It is rated as a P100 filter, and it blocks 99% of particles. But, when I sprayed Tamiya surface primer in my garage, I could smell the fumes. I was wearing this respirator, while spraying the primer. Does that mean this respirator is not good?
If you want some more research, here is the product, as well as the cartrige.
Made you Look
    January 2005
Posted by Watchmann on Monday, May 10, 2021 9:09 PM
Hi TM,
If you can smell the paint, that it's not what you want to use.  Look for one that works on paint, solvents, or organic vapors.
I use one like this from the same site.
Posted by Tojo72 on Monday, May 10, 2021 9:18 PM
If you can smell anything it's not effective or not fitted right.Did you not see the type I posted on your other thread.
    April 2021
Posted by SickBoy on Monday, May 10, 2021 9:18 PM
I get these at harbor freight, disposable but good for a lot of uses and come in two or three sizes depending on the size of your dome
https://www.harborfreight.com/p95-maintenance-free-dual-cartridge-respirator-66554.html
    January 2020
Posted by wpwar11 on Monday, May 10, 2021 9:23 PM
 Here is the one I use.  fit is comfortable and snug.  I don't smell any fumes.  I bought the compatible cartridges.
    January 2021
Posted by Teenage Modeler on Monday, May 10, 2021 10:19 PM
Watchmann
Hi TM,
Thanks for the tip. I'm pretty sure I can buy a cartridge for organic vapors for the type.
Made you Look
    November 2018
Posted by oldermodelguy on Tuesday, May 11, 2021 5:42 AM
Teenage Modeler
Watchmann
Hi TM,
The P100 might cover your need actually. But does the mask fit your face nice and snug enough to form a seal ? These masks generally are sold size specific. S M L XL. You want one that fits tight to your facial features and leaves no gaps.
Additionally the 3M and maybe others, have an outer hepa layer so the particles are caught in that, then the carbon fiber cartridge itself eats the vapors. You literally smell nothing but clean air even in a paint booth where you see dimly across the room through the mist in an extreme case of over spray ( been there done that).
    January 2021
Posted by Teenage Modeler on Tuesday, May 11, 2021 8:11 AM
oldermodelguy
Teenage Modeler
Watchmann
Hi TM,
Yeah, I made sure to test it right. I checked both positive and negative pressure checks, and they all were fine. I tested the mask by smelling a bottle of Tamiya Acrylics, but it went through, and could still smell the paint. I made sure it was right in front of the filter and not anywhere else, so I could make sure that the filter was a problem.
Made you Look
