Airbrush vs Paint
Airbrush vs Paint
Posted by Anonymous on Monday, April 19, 2004 12:48 PM
What acrylic paint has the finest pigment. The reason I ask, I was shooting Tamiya paint cut 3:2 water to paint through my Iwata HP-C+ and after a minute or so the paint began to dry on the needle tip disrupting paint flow. This only happens when I'm painting very fine lines. I cut the paint with water only to decrease the paints drying time. I have a suspicion that the problem is due to pigment size. Should I try another band of paint? What about a technique to keep the pigment suspended longer?
    July 2003
Posted by diggeraone on Monday, April 19, 2004 3:28 PM
I would suggest that a piece of sponge wetted with a piece of tape.Tape the wetted sponge over the tip to form a cap.This will keep the paint moist at the tip when you set it down for a few minutes.This should cure this problem without thinnig the paint any more.Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by Anonymous on Monday, April 19, 2004 4:23 PM
thanks Digger but allow me to clearify myself. The paint it drying on the tip during spray. To clear the dried paint I lightly clean the tip with a wetted Q-tip. To resolve the problem completely I have to flush the airbrush.
    July 2003
Posted by saltydog on Monday, April 19, 2004 4:38 PM
roman, i use tamiya acrylics and i have a plain old iwata hp-c. i dont know what size needle/nozzle you have in you're hp-c+. i personally bought the .4mm n/n conversion kit for my hp-c and it works much better than the factory .3mm n/n combo. however, i used the .3mm n/n for a couple of weeks until i discovered the larger n/n conversion kit. this is what ive found to work for me: when im doing fine line cammo i start my thinning ratio at 2 parts paint 3 parts thinner and with tamiya paints i reccomend biting the bullet and getting the tamiya thinner. water has too much surface tension to be a real good thinner for tamiya, plus, the tamiya thinner has drying retarders in with the alcohol mix to help with the tip dry. crank the pressure down to around max 12psi and min. 8psi. you should be able to find a sweet spot some where in that range. you may find it necessary to thin even further. you're gonna have to learn patience here because its gonna take more passes to build the color but you can achieve some soft tight edges this way. i usually put on all my cammo colors with a 50:50 ratio and clean up with the above ratio to save a little time. if you dont have any superlube, i'd purchase some asap. this little love potion helps tremendously with tip dry. hope this helps my friend. happy painting, later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Monday, April 19, 2004 4:47 PM
Don't thin tam acrylics with water, thats # 1. Tam acrys are fine paints, just thin them with iso or house stuff.
Posted by Anonymous on Monday, April 19, 2004 6:06 PM
Thanks for the great tips Saltydog. I didn't realize that tamiya thinner had drying retarders in it. I normaly thin my paint exclusely with tamiya thinner.
Posted by MikeV on Monday, April 19, 2004 7:16 PM
I think if he thins the paint with Iso then he may have an even worse tip dry problem as Iso tends to make paint dry quicker.
What he needs is a retarder as acrylics are notorious for drying quickly on the needle.
    July 2003
Posted by saltydog on Monday, April 19, 2004 8:26 PM
QUOTE: What he needs is a retarder as acrylics are notorious for drying quickly on the needle.
not if you use tamiya brand thinner. i cant stress this point enough. tamiya paints go through any of my airbrushes like a dream. its the only acrylic that ive really stuck with because it is so easy to work with. i rarely, if ever experience tip dry with tamiya. i may have to stop now and again and clean the tip, but its not much. i have to do that with enamels too though. later.
Posted by Anonymous on Monday, April 19, 2004 9:44 PM
the airbrush is only as good as the paint that goes thru it. Go with the cheap 99% iso, mixed 1:2:2 iso:tamiya thinner: gunze thinner. had most success with this mix, and straight iso is pretty good for cleaning.
