Please help — decanted Tamiya TS-45 Pearl White not covering
    July 2019
Posted by Bobstamp on Thursday, October 14, 2021 5:44 PM
I decided to change some decking on my U.S.S. Paul Revere hospital ship model from dark grey (painted with Tamiya XF-24 Dark Grey) to Tamiya TS-45 Pearl White to match the ships hull and superstructure. I first removed as much of the dark grey paint as possible with Mr. Paint Remover, ending up with very light grey decking. I decanted about a third of an ounce of Pearl White and repainted. I've now painted it with two coats of the decanted Pearl White lacquer, but it's not covering worth a darn. It's still very light grey — certainly not Pearl White.
What should I do!? Will another coat or two do the job, or should I go to Plan B (whatever Plan B is)? After the lacquer dries, could I use a coat or two of Tamiya Flat White acrylic paint, or will that likely get me in more trouble? (The brighter white paint shoud play reasonably well with other, nearby deck houses.)
Bob
On the bench: A diorama to illustrate the crash of a Beech T-34B Mentor which I survived in 1962 (I'm using Minicraft's 1/48 model of the Mentor), and a Pegasus model of the submarine Nautilus of 20,000 Leagues Under the Seas fame.
    April 2020
Posted by Eaglecash867 on Friday, October 15, 2021 5:07 AM
Did you remember to thoroughly shake the paint can right before decanting?
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    May 2009
Posted by Pawel on Friday, October 15, 2021 6:29 AM
Hello Bob! Painting white can such a sumbich... You might try two things:
1) painting the deck silver then putting white on top of that. Light gray primer might also be the way to go.
2) use white Tamiya primer from the spray can (love that stuff!). Then you might or might not put the pearly white on top of that to even things out.
Good luck with your ship and have a nice day
Paweł
www.vietnam.net.pl
Posted by gregbale on Friday, October 15, 2021 8:58 AM
Pawel's got it right. Whites tend to be stubbornly translucent, so a primer...preferably white or very light grey...is virtually a necessity.
Good luck.
Greg
George Lewis:
    November 2018
Posted by oldermodelguy on Friday, October 15, 2021 9:36 AM
I've shot about 3 iterations of pearl white and always use white primer under them. FWIW
    March 2015
Posted by JohnnyK on Saturday, October 16, 2021 10:21 AM
Yep, Tamiya white primer as an undercoat is the way to go. Use the rattle can. It works great.
    September 2021
Posted by DooeyPyle67 on Saturday, October 16, 2021 10:43 AM
gregbale
Good luck.
Pearl colors are translucent regardless. Pawel is correct, a white primer would work. Not only white is a hard color, try yellow sometimes. Enough to want to pull your hair or put  a hammer to your model kit.
I once used Pearl White on top of gloss white on a car kit. To be honest, it really doesn't change the appearance in color white at all.
    February 2006
Posted by Wilbur Wright on Wednesday, October 20, 2021 9:52 AM
I've used the Tamiya TS yellow, on a Ferrari model and it is like water. I will never use it again.
Multiple coats and it looks lemon yellow, not the deep yellow of the cap.  The primer color really matters if you are using these.
    November 2008
Posted by Justinryan215 on Thursday, November 4, 2021 8:06 PM
Wilbur Wright
many of you have never worked as an auto body painter, and it shows!  Lol
so, the pearl white is literally only the white pearl in a clear carrier.  There is very little, if any, pigment in it.  If there were, the white pigment would swallow up the pearl so that the pearl effect would not be visible. The white pearl is used to give it a special effect on the topcoat of white. For example a pearl white Cadillac is a white basecoat, over painted with a pearl topcoat and then a clearcoat. So that pearl coat you were using will never cover, you will always see that light gray.
As for painting yellow, there has been talk on several of the podcasts, that apparently the best undercoat color for yellow is actually a pink. Somehow the pink undercoat gives the yellow the ability to show it's vividness and saturation.
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
    January 2010
Posted by rob44 on Thursday, November 4, 2021 10:07 PM
"Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth..."
Justin - Love your quote from Ptolemy!
