Hi, Aggieman -
My airbrushes with the teflon type needle bearings, all perform better by using a compatible lubricant for the needle/bearing surfaces. I use Badger's lube, but others will do well also, such as coconut cooking oil, olive oil or grape seed oil.
Over long periods of use, I see no negative effect on the bearing material. I place a film of the lube on the forward part of the needle, insert it into the bearing to distribute the lube, then adjust the tightness of the bearing/needle interface. Once set it doesn't need adjustment again.
I am fairly certain the lube not only makes for smoother trigger feel, but also creates a better seal to ensure there is no fluid making it's way back through the bearing, to be deposited in the aft portion of the A/B body.
This has worked for me for many years, you might consider trying it. My CS clearly has benfitted well by doing it. I hope it works well for you.
Patrick
