Almost ready to start the decals and then the finish of my B-25J Mitchell. I do have several flat dullcote brands, but I also have the Testors TES1160 1.75Fl/oz dullcote and I guess I have never seen this before.
It has separated like enamel paints. Should just shake this up and then spray it or is this separation a good thing? I mean, when it was shaken, I saw that it was cloudy and wondered if I should use it or if it went bad. But now as I mentioned it is now separated. It has a very clear fluid in about 95% of the bottle and about 5% of the non-clear stuff at the bottom.
Maybe just use the clear portion?
Again, never seen this so unsure what to do; mix or use clear when ready to use.
