Is this crazy or a great idea? Or am I missing something?
I have learned through trial and error how to create "fuzzy" transitions from one colour to another on the models I've built: if I "elevate" masking tape or strips of paper secured with masking tape above the surface of a model, and mask the rest of the model to avoid unwanted paint, I avoid having sharp lines between the two colours. One colour just blends gradually into the other colour. The width of the fuzzy, intermediate area depends on the distance from the mask to the plastic. Less distance = sharper demarcation, more distance = softer demarcation.
What I would like to have is a soft, bendable cord in various diameters, from one or two millimetres to as much as a centimetre, coated with a removeable adhesive much like the Tamiya masking tape adhesive. It could be made of cotton, synthetic fibres, or foam rubber.
Such a cord could be used to create straight, geometric camouflage patterns or curved camouflage patterns. It would be especially useful for touching up errors.
For example, I oversprayed the wing of a model TBM Avenger I'm building and got a smallish drip of paint for my trouble. After sanding off the excess paint, it would have been nice to place a round cord around an eighth of an inch in diameter around the sanded area so it could be sprayed without creating sharply defined area of new paint that masking tape would have created. And, of course, I didn't want to add more paint to the wing, which was well covered except for the drip.
I made tubes of Tamiya masking tape and placed them around the sanded area, attached wide strips of masking tape and paper to the Tamiya tubes, and sprayed with good results. Here's a diagram showing what an ideal set-up, using purpose made "masking cord," would look like:
Your thoughts? Do you know of anything like "masking cord" that's already available?
Bob
On the bench: A diorama to illustrate the crash of a Beech T-34B Mentor which I survived in 1962 (I'm using Minicraft's 1/48 model of the Mentor), and a Pegasus model of the submarine Nautilus of 20,000 Leagues Under the Seas fame.
