Need a new Compressor
    July 2022
Posted by Piper on Monday, August 29, 2022 10:50 AM
Need to get a new compressor looking for suggestions . Want something quiet and reliable .
    April 2020
Posted by Eaglecash867 on Monday, August 29, 2022 1:30 PM
Here's what I'm using.  Its quiet and reliable, and has everything you need to start airbrushing right out of the box.
https://www.amazon.com/gp/product/B006ACB6D2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    June 2014
Posted by BrandonK on Monday, August 29, 2022 3:00 PM
I use an Iwata Smart Jet. Can't hear it and it runs even my high flow siphon feed brush. You can find them on sale from time to time. I've also heard some of the Harbor Freight ones are pretty good also.
Iwata-Medea - Smart Jet Compressor 1/8 Hp (IS850)
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2013
Posted by patrick206 on Monday, August 29, 2022 4:07 PM
I use two compressors, one for the garage and the other for my house hobby shop. Both California Air Tools, I'm completely happy with them both.
First I bought the large twin cylinder about 12 or so years ago, model number 1610-A. Hundreds of hours in use, zero issues, works like new.
For the house hobby area during winter I bought the single cylinder model   1P1060-S, same reliability.
The larger compressor is huge overkill for my modeling use, the single cylinder has all of the capacity I will ever need and more.
Enthusiastic recommendation for the brand from me. A few bucks more up front, but so well worth it long term.
Patrick
Posted by keavdog on Monday, August 29, 2022 5:24 PM
I'll throw my usual pitch for CO2.  Zero noise, no condensation, pretty cheap and very consistant.
Thanks,
John
Posted by Tojo72 on Tuesday, August 30, 2022 6:40 AM
Link won't work
    July 2022
Posted by Piper on Tuesday, August 30, 2022 7:24 AM
Thanks to all ! Looks like the Cal Air will be the one I get .
dlh
    March 2017
Posted by dlh on Tuesday, August 30, 2022 10:05 AM
https://store.sparmaxair.com/products/tc-610h-plus
This replaced my Master tankless.  It's very quiet.  It sits on the floor so I like the top mounted regulator.  A bit pricey though.  Can be had for a little less elsewhere.
Just my $.02.
    January 2022
Posted by Project510 on Tuesday, August 30, 2022 10:38 AM
I purchased my Badger TC910 Aspire back in January of 2016 and it has been perfect for me. When I purchased it, I was in an upstairs apartment so I needed it quiet for both the neghbor below me, and my sleeping wife in the next room. I never received any complaints. The only thing I had to do was put a bit of tape around the air release valve. It rattled against the case. I could have jsut removed the ring, since ive never once had to actually use it haha
___________________________________________
- James
WIP:
    November 2018
Posted by oldermodelguy on Tuesday, August 30, 2022 11:28 AM
I'm probably getting this one myself by Point Zero, to put inside a lower cabinet at my new work station. I have my large 8 gal houshold compressor I've used for years but want to set up this permenant airbrushing and modeling area. Anyway, this should be a link to the photo at Amazon, it's twin cylinder with a tank 59db:
Hmmm, well that link was a bust ! Anyway Point Zero twin cylinder, 1 gal tank, quiet 59 db. It's at Amazon for $117.
    January 2022
Posted by Project510 on Tuesday, August 30, 2022 1:51 PM
[quote user="oldermodelguy"]
[/quote\]
Did you mean this one? This looks like the same exact compressor as mine mentioned above just without the exterior case.
- James
WIP:
    November 2018
Posted by oldermodelguy on Wednesday, August 31, 2022 3:48 AM
[quote user="Project510"]
[/quote\]
[/quote]
Yes that's the one.
