Airbrush bad?
    September 2003
Airbrush bad?
Posted by out04 on Monday, December 26, 2022 9:12 PM
I keep getting paint between the cup and trigger assembly on my not young Iwata HP-CS.  Is this normal?
Posted by Tojo72 on Monday, December 26, 2022 9:56 PM
Sounds like a rear seal
    June 2014
Posted by BrandonK on Tuesday, December 27, 2022 9:59 AM
That's what I was thinking, rear packing or seal.
You might find this video helpful. https://www.youtube.com/watch?v=M41Gaxqanhc
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    September 2003
Posted by out04 on Tuesday, December 27, 2022 4:34 PM
A rear seal is a body replacement?  I don't see a rear seal on the parts diagram.  The needle packing screw maybe?
    June 2014
Posted by BrandonK on Tuesday, December 27, 2022 4:50 PM
Its called the "needle packing screw set with PTFE packing" part number 17251 from Iwata. You can buy them all over. You will need a special screw driver to take it out and put it back in as well. You don't need a body. Iwata does not show them in the parts diagram, but if you look at the "not pictured" list you will see it there.
I purchased an Iwata maintanence kit, CL500 on Amazon for $80. It has all the tools you need to work on these and since I have 4 airbrushes I know I'll need it sooner or later.
But, at the very least, you must have that screwdriver to do this.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    September 2003
Posted by out04 on Tuesday, December 27, 2022 7:51 PM
Ok, I found it and was able to get it out with a small flat head.  I'll replace it and see how it goes, thanks for the help.
    November 2018
Posted by oldermodelguy on Wednesday, December 28, 2022 6:07 AM
out04
It will be fine once done.
    October 2008
Posted by Don Wheeler on Friday, December 30, 2022 3:14 PM
You don't really need a special tool.  Just use something like a toothpick to get it started.  It's a touchy adjustment.  You may have to play with it a bit to get just a tiny bit of drag on the needle.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
