Strange issue with Iwata HP-CS
    May 2011
Posted by dazzjazz on Monday, January 30, 2023 3:52 PM
Hi al,
I've been enjoying my new Iwata HP-CS and getting good results until the last few spray sessions. Despite doing a thorough clean at the end of the session, using the supplied Iwata cleaner and their cleaning brushes, this is happening.
I press down for air, pull back for paint, but no paint comes out. When I move the trigger forward again, a small amount of paint comes out. Sometimes it will clear and spray for a second or two, then the whole issue repeats.
I currently have disassembled it. The main body is standing in isopropyl and I have the nozzle, nozzle cap and need cap soaking in Tamiya airbrush cleaner. I have to go out for a few hours, so I will try it later. Maybe there is some paint it the out let that is at 6 o'clock below where the nozzle is inserted?
What do you think is going on? I thought I've been doing all the right things. I've only used 'hot' solvents such as Tamiya airbrush cleaner sparingly, reasoning that the supplied Iwata cleaner shound be sufficient. I only use Tamiya and Vallejo acrylics.
    November 2018
Posted by oldermodelguy on Monday, January 30, 2023 4:10 PM
In my experience, periodically all the front end parts of airbrushes need stripping down and soaking overnight in lacquer thinner or acetone. And just fwiw and generally speaking, alcohol and Vallejo paints don't mix unless you're trying to simulate half dried tub and tile sealant. And there have been threads on cleaning airbrushes of acrylic paints, both while in use and changing out paint colors and for stripped down cleaning. Non the less, most recently in my world I'm still liking really hot water and either Iwata Medea airbrush cleaner to follow, then rinse with more water. Or I've found another option to be Zep industrial purple degreaser ( smells similar to the Iwata product actually). I backflush everything, just slide the needle out and wipe that then move on.. Thats for acrylics.
But on the tear down after a few sessions or weeks of the prior just mentioned, it's lacquer thinner or acetone, been that way for decades for me with several brands of airbrushes and spray guns and types of paint..
Posted by Tojo72 on Monday, January 30, 2023 4:43 PM
How about inside the brass nozzle.I clean inside it with those little dental brushes.
    May 2011
Posted by dazzjazz on Tuesday, January 31, 2023 2:32 PM
I spent time yesterday on the phone with the local Iwata representative. We couldn't resolve the issue so I'm sending to him for inspection/repair.
    May 2011
Posted by dazzjazz on Wednesday, February 1, 2023 4:50 AM
So tonight I thought I'd give the Iwata another once-over before sending it for warranty inspection. Long story short - the o-ring inside the quick release male connector had inexplicably expanded and was blocking a lot of air. Not sure why it had done that, as it never gets exposed to cleaner or solvents. I've now connected the airbrush directly to the compressor and it's working like a dream! That's the 2nd o-ring for the male connector that has failed. Anyone else noticed that?
phew ! I was beginning to think I was useless at airbrushes, or going mad, or both!
    November 2018
Posted by oldermodelguy on Wednesday, February 1, 2023 7:48 AM
IDK how either but on my Paashe VL the male connector of the quick disconnect that fits onto the airbrush thread the o ring can somehow get turned on edge down inside the airbrush passage. Makes 0 sense to me but the result in my case is an air leak, the brush still works as the ring is skinny and doesn't totally block the passage, just consuming much air.. I might see if maybe I can get a hardware store o ring that will fit in there ( unlikely since my local hardware has a rather small assortment of these.). However, if diligent I have found that I need to be sure the ring is fully down in the nut and fitting the outer groove ( in mine indeed there is a groove there for the ring). I have to take a tool and kind of pack the ring down in there. As it turns out the stem of the metal paint cup fits perfectly to seat that ring.Then lube the male thread with lip balm and assemble it, you can almost feel the male portion slip into the O ring then as it's lightly seated.
Posted by Tojo72 on Wednesday, February 1, 2023 9:22 AM
Yes,I have found if I make it too tight,no air at all passes,should be tight enought to seal,but not too tight to expand it.
    March 2013
Posted by patrick206 on Wednesday, February 1, 2023 3:31 PM
oldermodelguy
OMG -  The city near me is not all that big, but there are two great sources of air fittings and "O" rings there. One specializes in pneumatic everything, the other carries only O rings, any O ring I've ever needed they have.
Check your phone book or a Google search in your area, you might be surprised at sources available.
    November 2018
Posted by oldermodelguy on Thursday, February 2, 2023 3:11 PM
patrick206
oldermodelguy
Actually Patrick, I was in the hardware store today for something and took a look at the O rings and they go down to 1/8", so indeed there may be a size there that fits. I'll go in one day with my adapter piece. I also found out that the male nipple for the disconnect is a Paasche A-192, to which the fitting itself with O ring is $5 and change. I'm guess you can get the O ring separately though I did not see a number for it..
Meanwhile if I pack mine in correctly and lube the airbrush thread on assembly, lightly tightening all seems well. Additionally there is little need to take that apart if not leaking.
