Recommended Primer for Painting Acrylics with a Brush
    March 2023
Posted by Londoner on Monday, March 13, 2023 2:17 PM
Hello guys. This is my first post. I'm a noob on a shoestring & I want to know if anyone can recommend a good primer for paintbrushing acrylics.
    March 2023
Posted by Londoner on Tuesday, March 14, 2023 12:43 PM
Hycote plastic primer is well recommended, or should I stick with Revell's brush-on offering?
Posted by Tojo72 on Tuesday, March 14, 2023 12:58 PM
I assume you don't have an airbrush,I use Tamiya Extra Fine or Mr Surfacer 1200,although in a spray can,they can be easily applied without building up if you are careful,and they level out nicely,and are tough.
    July 2004
Posted by stikpusher on Tuesday, March 14, 2023 1:02 PM
Personally I prefer to airbrush primer on, to better control the amount applied. Rattle spray cans would be my second choice, and hand brushing on a primer a distant third. Primers tend to be a bit thick and can obscure fine surface detail when hand brushed on.
Tamiya makes some great primers that I've really liked. Gunze's Mr Surfacer products also have performed well in my experience. Lastly I've also been using Mig One Shot primers on several of my projects. The Mig product is probably the easiest to use, as no thinning is needed for airbrushing. Just put the stuff into your airbrush cup/jar, put your compressor at the recommended air pressure, and shoot it on.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2023
Posted by Londoner on Tuesday, March 14, 2023 1:19 PM
Thanks for your input guys. I haven't got an airbrush but intend getting one soon. For now I'll use a spraycan as I don't want to lose detail. It seems I can't go wrong with Tamiya so it's Extra Fine for now.
    July 2003
Posted by rfield on Wednesday, March 22, 2023 2:02 PM
I build mostly 1/72 AFVs and planes, and 1/9-1/12 busts. These days, I go as simple as I can without sacrificing quality; I've been using Krylon primers in white and gray, with no loss of detail (unless you just sit on one spot, of course).
Just be sure to shake it well to mix the innards.
    November 2018
Posted by oldermodelguy on Friday, March 24, 2023 4:42 AM
Londoner
The Mr line of primer surfacers will work as well.
    November 2018
Posted by oldermodelguy on Friday, March 24, 2023 4:49 AM
rfield
Krylon may well have changed their formulation since I used it as primer maybe 20 years ago. Back then without decanting and adding more thinner the only one IMO thin enough from the can to be in scale for models was the Platinum Gray. Assuming I was still putting a color coat on over the primer. That was using a hot water bath to heat the cans. Course I can't speak for Krylon today.
