Alclad II black base vs Alclad primer- First time use
    December 2005
Posted by Stuart06 on Saturday, June 17, 2023 5:10 PM
For the first time I am going to use Alclad II for a metal finish on a Ki-84.
What I picked up from the LHS is Alclad II black base.  After reading some more, they talke about Alclad II black primer.  - is these the same products (as I did not see the name primer on the shelf).
I also saw the Alclad II Black base & microfiller.  I thought about that, but thought that would reguire a lot of sanding (at least more then the others).  But is there an advantage to this product over the other Alclad primer?
Most of my friends are imaginary
Sell your watch, because time is money $$
In Canada hwy speed is measured by number of moose tracks per hockey goal.
Posted by keavdog on Saturday, June 17, 2023 5:28 PM
Alclad black base gloss is a great product but takes time to dry.  I typically use Tamiya gloss black as the base.
Thanks,
John
    April 2020
Posted by Eaglecash867 on Saturday, June 17, 2023 6:51 PM
I have never had much luck with Alclad's black base.  Like Keavdog mentions, it takes time to dry.  In my case, I waited about 3 weeks before giving up hope that it was ever going to dry completely.  I tried several other gloss black base coats to put under Alclad, with MRP's 2K Black giving the smoothest finish.  But, three drawbacks to that, its a 2K paint (which kind of scare me now after doing research on them), it took about a week for it to fully cure, and it was actually a little too hard and glossy.  The Alclad would flake right off of it.  MRP's regular gloss black lacquer was OK, but that dried a little too fast, and made it difficult to get a uniform gloss black.  Finally tried Tamiya's LP-1 gloss black lacquer, and that was the winner.  Dries quickly, but slowly enough to get a good, uniform gloss.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    September 2012
Posted by GMorrison on Saturday, June 17, 2023 8:50 PM
I don't like the Alklad stuff. Like John, Testors Gloss Black.
    March 2022
Posted by missileman2000 on Sunday, June 18, 2023 7:18 AM
I find any compatible gloss black is okay.  I have used Testors gloss and Tamiya Gloss Black Lacquer with good results.  I also have used various primers under the black undercoat.  A secret for Alclad is to cut way back on the flow and slowly build up the finish.
