Real G
Also, start off with flat white, as it covers better than gloss white. Then go over the flat white with gloss white. Tamiya's white primer is great for this.
Yeah, Tamiya white primer under any white will make that white practically glow. If you do t have that, then most any flat white undercoat will make your gloss white look bpetter. But the Tamiya white primer kicks it up several notches.
