flow control valve
    April 2023
flow control valve
Posted by John3M on Friday, July 28, 2023 12:26 PM
3M Accuspray Air Flow Control Valve, 16573
I'm looking to see if I can use this with a standard Iwata airbrush, I use this with a mini spray gun for large priming by Iwata with larger connections
i sent the image to postimage but Im unable grasp exactly how it works
    May 2011
Posted by Real G on Friday, July 28, 2023 12:47 PM
I don't see why not.  You just need the right connectors to the compressor and airbrush hose.  There are increaser/reducer couplings as well as metric to inch fittings.  Your hardware store should be able to provide what you need.
You will also need a moisture trap.  You can get one with a regulator as a single unit.  The regulator you mentioned does not appear to have a moisture trap.
“Ya ya ya, unicorn papoi!”
