Looking for a valvee
    April 2023
Posted by John3M on Friday, August 4, 2023 10:55 AM
Is there a regulated valve with gauge? I'm interested in putting an inline Valve on the airbrush air hose. My pump has one it also has a tank, however i am thinking there must be a way to have constant pressure at the airbrush so I would crank up the pressure at the tank to +- 50 psi and the valve I'm looking for would step down the pressure at the pressure level I select, 20 psi+-  I purchased a regulated valve but all it does is show the psi in the tank I can turn psi down but it will not now show the psi I want on the gauge. like 20psi
    August 2005
Posted by EdGrune on Friday, August 4, 2023 1:25 PM
I use a Harbor Freight regulator with gauge. It is standard air hose fittings.  Used to be about 10 bux.  Don't know what they run now. Use a set of quick disconnects out and into hose reducer. Gauge on the unit was 180 PSI full scale but I replaced it with a 30 PSI one off of Amazon  Most of the fittings are typical big box hardware items
Lowes and Home Despot may have a similar unit
