Can I use acrylic over a lacquer primer???
    April 2023
Posted by KeithRob on Friday, August 18, 2023 9:23 PM
I primed my Tamiya Bradley IFV with Mr Surfacer 1500 black and want to paint it desert yellow with Tamiya acrylic.  I know 1500 is a lacquer. . . .I get confused about what paint works with what. . .  . Is this ok????
"Charlie don't surf!"
Lieutenant Colonel William "Bill" Kilgore
Posted by Tojo72 on Friday, August 18, 2023 9:52 PM
Yes you can
    April 2023
Posted by KeithRob on Friday, August 18, 2023 10:01 PM
thank you.
    November 2018
Posted by oldermodelguy on Saturday, August 19, 2023 5:16 AM
Not to shake the forum up but Mr Surfacer is actually acrylic in a lacquer-esque solvent. One big main ingredient of the solvent being acetone.
The solids are acrylic resin and aluminum powder. It does grip plastic very well.
Just sayin, as the coffee starts kicking in.
Posted by keavdog on Saturday, August 19, 2023 11:50 AM
I find this reference helpful
Thanks,
John
    April 2023
Posted by KeithRob on Saturday, August 19, 2023 11:54 AM
Thanks!
    April 2023
Posted by ctruss53 on Monday, August 21, 2023 8:56 AM
I know you already got your answer, but I wanted to add something.
I use Mr Surfacer primer on all my builds because I have not found any paint it will not work with. It is very versatile.
There are two exceptions to this......
1. Enamels. I refuse to use enamels, so I don't know if they will work over Mr Surfacer. They probably will, but I don't know.
2. There is a new automotive polyurethane paint I started using on some of my builds. It is so hot that no hobby grade prime will stand up to it. I have to use automotive grade primer.
But other than those two things, Mr Surfacer is my favorite primer. I use it in spray can form. It lays down smooth, and works with nearly any paint.
Insert wise quote here.
-Chad
    November 2018
Posted by oldermodelguy on Monday, August 21, 2023 11:11 AM
Text removed,it's quoted in my own reply to this one lol.
    November 2018
Posted by oldermodelguy on Monday, August 21, 2023 11:33 AM
oldermodelguy
MR. PRIMER SURFACER 1000
SF287
Detail
This is a surfacer with primer (base filling paint).
The material used in Surfacer 1000, which is gaining overwhelming popularity for plastic models has been improved for this product.
Surface attachment has been enhanced not only for plastic models but also for metal in etched parts and resin.
Spray type and bottle type are available. Color is gray.
I posted this because I think a lot of people using Mr Surfacer may not have realized this is out there. Note that it says "Primer".And read the smaller print in the post. Also if you compare products the ingredients are a bit different. I have both, I have the one I posted in the bottle that I thin maybe 30% with Mr Leveling thinner and it goes on very smooth. Then I have the regular surfacer in spray can which goes on smooth.
Now Chad brought up enamel. I've shot enamel, the Rustoleum 2X semigloss that actually comes out more gloss than semi. Anyway on Mr Surfacer it went on mostly well but I noticed some spots where it seemed almost as though it soaked into the Surfacer and left it flat and rougher than the rest of the spray job.. By contrast, that has not happened over Stynylrez, which is a Primer/Sealer. Eventually I'll try it of the Mr Primer Surfacer.
    April 2023
Posted by ctruss53 on Monday, August 21, 2023 12:49 PM
Wait.  Mr Primer Surfacer is supposed to be BETTER than Mr Surfacer?
How can you improve on perfection?  haha
But seriously. Mr Surfacer is so good. I can't imagine something better.
-Chad
    November 2018
Posted by oldermodelguy on Monday, August 21, 2023 1:07 PM
ctruss53
To keep it on topic with the thread, either should be fine under acrylic.Off TopicBig Smile
