Lacquer Over Water Based Acrylics
    July 2023
Posted by Colonel Klink on Monday, February 5, 2024 4:30 PM
Can I spray lacquer paint or clear coats over dried water based acrylics?  I generally use Mission Model, Vallejo and Tamiya XF paints.
Thanks.
Posted by keavdog on Monday, February 5, 2024 4:41 PM
I found this to be a useful diagram to save
Thanks,
John
    April 2020
Posted by Eaglecash867 on Monday, February 5, 2024 4:51 PM
Colonel Klink
Can I spray lacquer paint or clrear coats over dried water based acrylics?  I generally use Mission Model, Vallejo and Tamiya XF paints.
Thanks.
I do that on a regular basis with no issues.  As long as you don't go too wet and heavy with the lacquer you're spraying, you should be fine.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    February 2021
Posted by MJY65 on Monday, February 5, 2024 6:06 PM
Eaglecash867
I agree. The first coat of lacquer needs to be VERY light to avoid burning into the acrylic.  Each subsequent coat can be a little heavier as you build it up.
    July 2023
Posted by Colonel Klink on Monday, February 5, 2024 8:42 PM
Cool.  I apreciate the feedback!
