Issue with Advanced GHAD68
    September 2019
Posted by Top2MP on Tuesday, February 13, 2024 3:23 PM
I love this airbrush, but after cleaning it, it spits out drops of paint before starting to spray. I've taken it apart a few times trying to find the problem with no success.  And if I point it down, it drips.  Any ideas?
Thanks
    November 2018
Posted by oldermodelguy on Sunday, February 18, 2024 12:46 PM
Usually dual action top feed airbrushes can drip if the needle doesn't return to the seat properly. That would include the spatter at the start of a pass of spray. Other than that I know nothing about the model of airbrush you listed.
    October 2019
Posted by Tanker-Builder on Monday, February 19, 2024 5:59 AM
Although:
      I am not familiar with the unit you call out, I will say it sounds like you have a problem like I had with my old DeVillbis fine spray unit. An "O" ring is either split or twisted in the barrel and needs replacing. Probably the one closest to the tip. How old is the unit and what do you clean it with? Once in a while Like a gun, you have to break it down to it's components to refresh the parts and replace the worn ones.
