Spraying Future?
Spraying Future?
Posted by Anonymous on Monday, April 26, 2004 7:17 PM
Hi. Can Future be sprayed with out thinning?
Thanks.
John
    January 2003
Posted by therriman on Monday, April 26, 2004 7:25 PM
YES. I airbrush right out of the bottle. I use windex to clean up.
Tim H. "If your alone and you meet a Zero, run like hell. Your outnumbered" Capt Joe Foss, Guadalcanal 1942 Real Trucks have 18 wheels. Anything less is just a Toy! I am in shape. Hey, Round is a shape! Reality is a concept not yet proven.
    January 2004
Posted by MusicCity on Monday, April 26, 2004 9:48 PM
Sign - Ditto [#ditto] It sprays just fine right from the bottle, and like therriman I used Windex to clean my airbrush out, and then a shot of plain old water to wash out the Windex.
When you get right down to it, you could spray motor oil right out of the bottle, it would just take a lot of pressure. Air pressure and thinning are a balancing act. Thick mediums need more pressure but they tend to cover better. Thin mediums spray at lower pressures, you will tend to have less overspray, but they don't cover as well. Find the consistency of paint that covers well for you, then adjust your air pressure to the lowest that will allow it to spray properly and you should be in good shape.
Posted by Anonymous on Monday, April 26, 2004 11:36 PM
Do you guys clean your airbrush by spraying windex only, or do you also disassemble the entire airbrush for thorough cleaning after using Future?
Posted by MikeV on Monday, April 26, 2004 11:53 PM
Sigman,
I don't recommend you disassemble the airbrush for cleaning very often as it is unnecessary and leads to a shorter life for parts.
After spraying Future I spray some of my infamous "elixir" as some here call it, of 2 parts distilled water, 1 part Windex, and 1 part Simple Green cleaner through the airbrush. I then backflush it with a little more cleaner, and then spray a little more cleaner through it after backflushing. Then I spray some straight distilled water through it, wipe the cup with a cotton rag and put it away.
That's all that's necessary. Wink [;)]
Posted by Anonymous on Tuesday, April 27, 2004 12:30 AM
QUOTE: Originally posted by MikeV
Sigman,
That's all that's necessary. [;)
How about your process of cleaning an airbrush MikeV?
Posted by MikeV on Tuesday, April 27, 2004 7:23 AM
It is pretty much the same thing. I spray some cleaner through it, then fill the bowl about 1/2 way again and then use a wide 1/4" or so paint brush to wipe around inside the color cup and down around the needle area to break loose any paint there.
I turn the regulator up around 40-50 psi, then I spray out that cleaner I just used the brush in, fill it about 1/4 way again and backflush it a little, then spray that out.
I then fill it about 1/2 way again with cleaner and blast it all out, then I fill the cup with filtered water and spray all of that out, wipe the inside of the cup with a soft rag, clean off any paint that is on the outside and put it away.
I disassemble it only when I feel like I didn't get it quite clean enough the time before or when it feels like it needs to be lubed again, which is usually every 4th or 5th painting session maybe. I always use Badger Needle Juice lube or Medea Super Lube in the airbrush as it keeps the airbrush's action smoother and it keeps paint from adhering to the needle as it will without lube.
I hope that helps Wink [;)]
Posted by Anonymous on Tuesday, April 27, 2004 7:57 AM
Thanks for the info MikeV. Now, I can airbrush more often because I always disassemble my airbrush every session to clean everything and the next time I wanted to paint, it discourages me because of the entire cleaning process.
    January 2003
Posted by stinger on Tuesday, April 27, 2004 1:18 PM
Unlike the other responses here, I have not had good results with spraying Future straight from the bottle. It leaves a pattern that is very rough on the edges and each successive pass will not "blend" into the previous pass. I tried all different pressure settings down to the lowest that would push it through my airbrush (Iwata HP-CS). I thinned it with Denatured Alcohol and finally got it to blend.
Am I doing something wrong here? Is it maybe that even though it doesn't appear to blend at first, it will level out eventually?
Any help would be appreciated.
Thanks,
stinger
May an Angel be your wingman, and the Sun be always at your six
Posted by Anonymous on Tuesday, April 27, 2004 5:52 PM
Just a note of intrest, i have a converted bottle assembly that fits right into a bottle of future, its a bit heavy, and the straw thing can fall out, but just spraying almost a litre of future, thats priceless
    July 2003
Posted by saltydog on Tuesday, April 27, 2004 6:32 PM
stinger, blending the edges is kinda tricky, but this is what works for me. first, your paint job has to be nice and smooth (as if you didnt know that). then, (and i use the hp-cs too) straight from the bottle, i "dust" the future on at about 20psi and about 2 to 4 inches from the surface and build the dust to a "wet" coat and then repeat the process on across the subject lapping my last pass. this works well for me and i get a nice glossy surface to wash and decal. hope that helped. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    January 2003
Posted by stinger on Wednesday, April 28, 2004 6:12 AM
Thanks Salty, I'll try that method next time.
When you say "smooth", I assume you mean no orange peel or dust specks, etc. I've been spraying the Future over flat paints before decaling. This may sound stupid, but should I be doing something to the flat finish to make it "smoother" before applying the Future?
stinger
