Hello, I am new to Vallejo Paints first of all and I have just air brushed a Vallejo Model Color paint thinned with Vallejo thinner and let dry overni
    January 2017
Posted by cadman on Sunday, June 2, 2024 11:11 AM
Hello, I am new to Vallejo Paints first of all and I have just air brushed a Vallejo Model Color paint thinned with Vallejo thinner and let dry overnight. I wanted to see how well it adheres to the plastic with my finger nail and noticed how easy it comes off the plastic not like Tamiya acrylics. How do you paint with these Vallejo Model paints? Vallejo has some colors I really like that Tamiya does not have? Thanks in advance, George
Posted by Tojo72 on Sunday, June 2, 2024 6:20 PM
Vallejo has a nice color range,but you need a good primer like Tamiya Extra Fine or Mr Surfacer 1200,I use either in a rattlecan
    November 2018
Posted by oldermodelguy on Monday, June 3, 2024 4:10 AM
I use Stynylrez primer under vallejo paints. I also flash dry each coat with a hair dryer ( I do that with most waterborne acrylic paints) and that speeds the overall dry time as well. Following this, the Vallejo range of paints do much better adhering and I believe, level off faster. Waterborne ( not just Vallejo) acrylic paints dont do well applied directly to plastic. They do stick to primer well and the primer sticks to plastic well.
I can't speak of the thinner, as I use my own blend. Some folks like the Vallejo flow improver, either in part mixed with the thinner. Or some use it completely straight to thin MC.
Tamiya acrylic is very lacquer-esque, but alcohol based. In my personal tests of the stuff, yes it will stick to plastic, but it's more durable with a primer under it. A primer like the Tamiya mentioned above or as I personally like, Mr Surfacer 1000 or Mr Primer Surfacer 1000 is a good type primer to use. Stynylrez works too.
    November 2023
Posted by Fisherman Dave on Monday, June 3, 2024 5:54 AM
The only time I have a problem is with the plastic I had to repaint my Revell S-100 3 times getting more aggressive cleaning each time. Is the primer scratching off with the paint ?
Posted by Tojo72 on Monday, June 3, 2024 2:54 PM
Just watch that Stynylrez primer,it will jam your airbrush up in blink of an eye if not used and cleaned out properly
    November 2018
Posted by oldermodelguy on Monday, June 3, 2024 3:28 PM
Tojo72
True, it needs cleaning immediately. But if you do that, it's easy to clean.Iwata media airbrush cleaner works well on it, for one cleaner. If you let it sit then try to clean, it can be very hard stuff.
    September 2006
Posted by the Baron on Tuesday, June 4, 2024 7:29 AM
I will second Tojo and OlderModelGuy, you should use a primer to promote better adhesion, particularly with water-soluable acrylics like Vallejo.  I always use a primer, Tamiya's Fine Surface Primer.  I have used automotive primers, too, like Rustoleum and Walmart's house brand.  In my own experience, painting figures with Vallejo's Model Color, I have found that it is more susceptible to rubbing off and I try to handle a piece as little as possible, till I can seal the piece.  I use a universal clamp, for example, or I insert pins in the piece and stick it on a cork.
I will add that while Vallejo's Model Color can be airbrushed, that line is formulated for brush-painting.  Vallejo's Model Air paints are formulated specifically for airbrushing, and Vallejo makes additional products that can be used with those paints for airbrushing.  It's not necessary to use Model Air and the adjuncts for airbrushing, as others might say. But it's about increasing the odds of getting the best results with the least fuss.
Eventually, though, you might also get comfortable mixing colors, and find that you can use any particular brand's colors to get what you want.
Hope that all helps!
Best regards,
Brad
    June 2014
Posted by BrandonK on Thursday, June 6, 2024 9:43 AM
I use most of the popular paints and Vallejo is my favorite for color. It is very different to use than all the rest however and must be primed. It is also a delicate paint once painted down and must be handled as such. Once you have your project sealed it is more like other paints in durability. If you use it and handle it with care while working on the kit you will be happy, but don't expect it to take tape and rough handling like Tamiya, Gunze and others. It is also the best paint for brush painting, bar none, impo.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    September 2006
Posted by the Baron on Friday, June 7, 2024 8:39 AM
BrandonK
I use most of the popular paints and Vallejo is my favorite for color...
Just to clarify, do you use Model Color, Model Air, or both?
    April 2010
Posted by Mustang8376 on Friday, June 7, 2024 10:38 AM
I use Vallejo mostly and I will agree with everyone.  You have to prime it and let the primer dry before doing anything else.  Once you paint, make sure the paint has dried also.  Very aggressive handling with remove it, but then that is most paints in my opinion.
Current build: 1/48 Monogram A-1H & AMT Jedi Starfighter.
Completed:  1/48 Monogram/Revell P-61B, 1/32 Hasegawa F6F-5, 1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
fox
    January 2007
Posted by fox on Friday, June 7, 2024 10:48 AM
I also use Vallejo Model Air almost entirely. I use Rustoleum primers (White. Grey, and Black) all the time with no problems. Sometimes I use the primer out of the can and other times I decant it and use in my airbrush depending on the size and shape of the pieces.
Stay safe.
Jim Captain
 Main WIP:
    June 2014
Posted by BrandonK on Saturday, June 8, 2024 9:09 AM
the Baron
BrandonK
I use both, but for brush painting I prefer Model Color as the pre-thinned Model air is more difficult to brush paint as it is a tad too thin, but will work. For Airbrushing I use both, but again I prefer the Color over the Air as I can control the thinning more and how it sprays. I have more diffuculty getting the Air to spray how I like, but I manage.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    May 2006
Posted by Shipwreck on Sunday, June 9, 2024 2:32 PM
I use Vallejo and Tamiya paints; preferring Vallejo because it smells better. If I were to use a non-water based primer I woud be introducing oder with it. That is why I use Valleyo primers.
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    September 2006
Posted by the Baron on Monday, June 10, 2024 12:42 PM
BrandonK
the Baron
BrandonK
BK
Thanks, BK!  OK, yeah, that doesn't really change the advice we've given you for your initial question.  With either Vallejo product, it's a good idea to use a good primer with Vallejo's paints, Model Color as well as Model Air.
    June 2014
Posted by BrandonK on Monday, June 10, 2024 3:20 PM
Any primer is better than no primer with Vallejo paints.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    April 2006
Posted by waynec on Saturday, July 13, 2024 7:10 PM
I use Vallejo primer before painting. it needs 24 hours to cure but, after that, it is fine. i use the different colors for different effects. I airbrush mostly Vallejo Air but sometimes Model Color. i do not seal my builds before weathering and i weather with oils, paint, pastels and weathering materials. Other then letting the primer cure i have not had a problem with lifting or sanding.
i will sometmes hit the primer and paint with a hair drye. Sometimes i will use rustoleom primer if the temperature is not too hot and i can spray in the garage. I still miss Model Master Acrylics.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
