PROBLEM
PROBLEM
Posted by Anonymous on Wednesday, April 28, 2004 5:05 PM
In the process of building my diorama I found I needed a truck which I was able to getCool [8D] Now in the process of building this truck I realized that the tires (which are real rubber) required a finish that would make them look more like real tires as the ones in the kit were shinyConfused [%-)] I tried using a flat clear which turned out great colorwise until I tried to put everything togetherBanged Head [banghead] The paint I put on the tires immediately started to peel whenever I put any stress on the tireCensored [censored] Now after all that, what shoud I have done to make the tires look like real rubber instead of something that has been treated with armorallQuestion [?]Question [?]Question [?]
Help pleaseBig Smile [:D]
Richard
    January 2004
Posted by MusicCity on Wednesday, April 28, 2004 5:39 PM
I always just use some steel wool to scuff them up, but mine never really look "Real". If you run across a good way I'd appreciate knowing what it is!
I haven't tried it, but something like acetone might eat them a little and take the shine off. I'd try it on some scrap first though.
Posted by Anonymous on Wednesday, April 28, 2004 5:45 PM
Music City
If I get any good info or find something that works I will let you know.
Richard
    July 2003
Posted by Foster7155 on Wednesday, April 28, 2004 6:10 PM
As with vinyl tracks in armor kits, I always paint "real rubber" tires with plain black acrylic paint first. This will adhere when enamels and laquers will not. Then, you can dry-brush or weather the tires in any way you wish.
Foster
Robert Foster
Pensacola Modeleers
Posted by Anonymous on Wednesday, April 28, 2004 7:29 PM
Foster,
Thanks, I will give it a try.
Richard
    January 2003
Posted by shermanfreak on Wednesday, April 28, 2004 9:39 PM
I go with the scuff them up method ..... light scuffing with sandpaper and then some pastel chalks for dust and call it a day.
    July 2003
Posted by KJ200 on Thursday, April 29, 2004 7:34 AM
Try painting them with PVA, ie Elmers.
This acts as a sealing coat.
Not sure where I heard about this, but I know it works.
Karl
    May 2003
Posted by styrene on Thursday, April 29, 2004 2:25 PM
Simpler solution:
I paint my hubs and then slip the rubber tires over the hubs when dry. I then spray Testors flat over the whole thing, wash the hubs, and then drybrush it all. You can then apply pastel chalks, if you desire.
My 88 in the picture below has rubber tires over plastic hubs/rims.
Make sure you wash the tires prior to assembling them to remove any residual mold release.
Hope this helps.
Gip Winecoff
