If you decide to use these bottles make sure that you pick up a regulator to control the amount of pressure you are sending to your airbrush. I have heard of a number of people succesfully using this arrangement but have no idea about how long it will last you. I would suspect quite a while. As far as purchasing a compressor, my only suggestion would be not to limit yourself to one that is designed for hobby work. Check out any major hardware stores or if you are in the U.S....Walmart. I just purchased one for $139 Canadian from a hardware store complete with regulator. Another $10 for a moisture trap and I was off and running.
Happy Modelling and God Bless
Robert
