Floquil paint & priming
  • From: directly above the center of the earth or known as Dixon, IL.
Posted by NEW MEX on Sunday, May 2, 2004 5:18 PM
Just came across some old Floquil railroad colors i forgot i had and they are still good.question is what kind of paint are they and how are they thinned? i forgetDunce [D)] also i'm going to be using MM acrylics on my resin and multimedia ship model, should i prime it and if so with what?
    May 2003
Posted by qmiester on Sunday, May 2, 2004 7:09 PM
The origional Floquil RR paints were a laquer which were designed to be used on metal and wood. They had their own thinner which was called dio-sol. They were definately not styrene compatable - if you brush painted styrene it would soften and craze the plastic. They eventually came out with a product called Barrier which apparently was a clear primer which did not react with the plastic and the paint would not react with the primer. However, if you used an airbrush and sprayed very thin coats, you could get very good results with Floquil RR paints on plastics. Only thing was, you weren't going to strip the paint if you needed to. Don't know if Dio-sol is still available - you might check at your LHS.
The few times I've used Acrylics, I've primed with automotive grey primer and it seemed to work ok
Quincy
Posted by rjkplasticmod on Sunday, May 2, 2004 7:37 PM
You can thin the older & the current Floquil MRR paints with Lacquer thinner. Diosol is not needed. For primer, I use the Floquil grey primer available in the current MRR paint line.
Posted by NEW MEX on Sunday, May 2, 2004 9:07 PM
Thanks guys for the info.i appreciate all the help i can get. after being gone from the hobby for so long there's a lot of stuff i've forgotten and a lot of new things to learnWhistling [:-^]
Posted by Anonymous on Monday, May 3, 2004 3:53 AM
Definitely prime resin first if you are using acrylic paint. Acrylic will peel off from resin when handled too much.
Floquil could either be lacquer or enamel. I believe the lacquer stuff only game in 5/8 oz bottles before they switched to 1/2 oz bottles. The lacquer really stinks. It can be thinned with lacquer thinner or the current Floquil thinner which also works with their enamel stuff. The enamel railroad colors are still in production.
