Good compressors in the UK
Posted by Anonymous on Tuesday, May 4, 2004 3:51 AM
Can anyone in the uk recommend a GOOD compressor I went to Focus(Local DIY store) last week and bought one on "offer" for £79 6 litre tank moisture relief valve etc but the thing put out when switched on 99dba Shock [:O]Shock [:O]
Thats a level 2 noise hazard area in the spare room!!!!.
The dogs and cat went ape! Mind you so did KathAngry [:(!]Angry [:(!]
I have heared that there are problems with the Badger compressor with con rod and bearing wear that once they go thats it???
So at present I have airbrush but no compressor and there is now a long line at the paint shopConfused [%-)]Confused [%-)]Confused [%-)] HELP
Thanks Nick
    July 2003
Posted by KJ200 on Tuesday, May 4, 2004 7:23 AM
Nick, I've got a Werther 3.
Noise levels are relatively low, it has an internal 0.8L storage tank, it is a piston rather than a diaphragm type so no pulsing, and it cost me a £100.
I've had mine about 6 months and it's been fine, apart from me dropping it off a table and mashing up the internal chassis. However having super glued it all back together again, it's been fine ever since.
Try the link below:
www.maywoodgroup.co.uk/Compressors/SearchResult.aspx?categoryID=15
Karl
Posted by Anonymous on Tuesday, May 4, 2004 8:35 AM
Thanks K arl I have had a look seems ok for the price
    July 2003
Posted by KJ200 on Tuesday, May 4, 2004 9:56 AM
If you want somethjng a little meatier, try Screwfix Direct, who have a Wolf compressor, with a large tank, for under a 100.
Karl
Posted by Anonymous on Tuesday, May 4, 2004 6:17 PM
or an iwata sprint jet.
Posted by Anonymous on Wednesday, May 5, 2004 2:09 AM
Thankee peeps
