Sorry to seem to be a little obsessive about this spray booth fan issue... but...
I have decided to go with a DIY version using a dedicated squirrel cage unit, and am now trying to determine if I should use a 265 CFM or a 428 CFM shaded pole blower. Both are from Dayton, here's a link to the larger one:
http://www.grainger.com/Grainger/productdetail.jsp?xi=xi&ItemId=1611769254
The smaller of the two is pictured on the left hand side of this page. I am curious / concerned though about the actual fan portion of this larger blower. In the photo, it seems like the fan unit may extend into the main blade area... either that or it is a very flat fan motor. From whatI've read the whole idea is to have the motor away from the blades.
Also, as far as the CFM amount. Without knowing what this sort of pressure actually feels like in person, it's difficult to make an informed decision.
I suppose if I bought the larger one, and it was too much draw, I could build some type of baffle to reduce the air flow.
I'll be making the spray booth housing (approximate size) 30" wide by 16 "deep... not sure about the exact dimensions yet.
Given that the larger unit is only about $20 more, seems like the way to go.
If there's anything I'm missing here. I'd appreciate hearing it before I buy the fan / build the booth.
Thanks again,
John
