Thinning paint
Thinning paint
Posted by Anonymous on Wednesday, May 12, 2004 11:58 AM
Hi. I understand that paint should be thinned to about the consistancy of 2% milk which is about 3 to 1. I have been thinning about 2 to 1 and spraying about 15psi. It seems to work fine. Obviously I am just learning to airbrush. Does this combination seem to be about right?
Thanks.
John
    January 2004
Posted by MusicCity on Wednesday, May 12, 2004 12:18 PM
John, that sounds fine to me. If the paint is flowing properly through your airbrush, and you are getting the coverage that you want then that's what counts.
The actual ratio depends on type of paint, type of airbrush, and how you paint. For example, if the paint has been left open in the bottle, you might have to thin it a little more than normal because some of the solvent will have evaporated making it a little thicker. Some metallic paints are pretty thick and others are pretty thin right from the bottle so you might have to adjust some in cases like that. How well it paints is more important than the actual ratio of paint to thinner.
Posted by Anonymous on Wednesday, May 12, 2004 1:50 PM
Ditto MusicCity !!!!
What type of paint and brands of paints are you using StarWars?
Cheers!!!! Cool [8D]
Kelley Eight Ball [8]
Posted by Anonymous on Wednesday, May 12, 2004 4:41 PM
I'm keeping it simple, I'm just using Model Master for now. Hopefully once I get the basics down, then I can try some other brands of paint.
Posted by Anonymous on Wednesday, May 12, 2004 5:50 PM
model master are goods. me good at english. unpossible to fail
Posted by maddafinga on Wednesday, May 12, 2004 7:50 PM
Hah. Leet's last name is Wiggums.
I personally like to thin my paint to the consistancy of skim milk, but that a personal thing. The important thing is that it's working for you, you're not getting bad spattering or anything like that. If that's the case, keep doing what you're doing. You'll find sometimes that you need to thin some colors or jars more, some less, it'll also depend on what you're trying to paint and the situation. If what your'e doing works, stick with it man.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
    January 2003
Posted by plasticmod992 on Friday, May 21, 2004 6:20 PM
Trying to figure out the "skim milk" thinning approximation can be largely subjective, confusing and frustrating. The time tested general ratio for thinning model paint tends to be 2 parts paint-to- 1 part thinner. For fine lines and detail work try a 1:1 paint-to-thinner ratio. These are basic starting points. Test spray the mix on a scrap sheet of styrene or junk model part; if the paint flow is still a bit too thick(ie. spattering, flecks of paint along the spray pattern, etc.) add a drop or two of thinner. If the mix is too thin (ie. paint spray is transparent on the model surface, dosn't cover well after a few light coats, paint spray is very runny after contating the model), simply add a drop or two of paint. I've been doing this way for 20 years without a problem. Its worked for me using acrylics and enamels. Happy modeling!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by MikeV on Friday, May 21, 2004 7:38 PM
Good advice Greg. Wink [;)]
Posted by Anonymous on Saturday, May 22, 2004 1:32 PM
Maddafinger: im confusid. and if you are refering to me, its 1337, not l33t, tho thats the purpose of that.
Posted by kfinger on Sunday, May 23, 2004 6:14 AM
I'm new to air brushing, what is working for me is the model master paints. A gravity feed air brush approx 15 psi thinned down to a milk consistency. I thin or thicken it after test spraying Kurt.
    January 2004
Posted by MusicCity on Sunday, May 23, 2004 7:26 AM
That's the key, Kurt. The fact that it's working for you.
IMO there is no single, best way to paint. The "Best" way is the way that you like and the one that works for you under most circumstances. You may have to adjust things for a particular bottle of paint or for a particularly difficult area to be painted, but once you find a general "Recipe" that works, and unless a person happens to be way off base, the best thing to do is to stick in that general area because it's what you get accustomed to feeling. Thick paint vs. thin paint or high pressure vs. low pressure covers different and "feels" different. I'm not experienced enough to be able to adapt to changes quickly, so I prefer a combination that doesn't surprise me when I use it.
