Crown Aircap
Crown Aircap
Posted by Anonymous on Tuesday, May 18, 2004 10:28 AM
Hi All...This little gadget, shaped like a small crown, is supposed to help delete overspray by allowing extra air to excape through the small gaps around it's side. I don't get much spray even though I have tried all three size needles with it. My airbrush is a Paasche and works well with a regular cap. Any ideas?
    January 2004
Posted by MusicCity on Sunday, May 23, 2004 7:01 AM
I have a crown aircap for one of my Badger brushes, but it came with the tip and I never thought anything about it. I haven't noticed that it decreases the amount of paint flow though.
What pressure are you painting at? I usually use around 15 psi or less and seldom get any significant overspray to start with.
Posted by Anonymous on Sunday, May 23, 2004 10:22 AM
Thanks Scott.....My compressor can't be adjusted but I plan on getting a better one at Dixie Art in New Orleans as soon as I can. I'll try a change of psi then and see if it does the trick. Appreciate the info.
    January 2004
Posted by MusicCity on Sunday, May 23, 2004 11:01 AM
Tommy, you might be able to add a regulator to your compressor. It just depends on the fittings. If they are so that you can just screw a regulator on then it would only be a $20 fix and give you a more usable compressor. If you had to buy a bunch of adapters and stuff it might not be cost effective or worth the trouble.
I think most of the "Hobby" type compressors that don't have a regulator are set around 30 - 35 psi. If so that's the cause of most of your overspray. I paint at about 15 or less and I think most others do as well. At 30 you have to back so far away from the surface to keep the paint from puddling and running that most of the paint just blows everywhere. At 15 or less you can get real close to the surface and the paint doesn't blow everywhere.
Posted by Anonymous on Monday, May 24, 2004 7:39 AM
Thanks again Scott...Roger on that, pal. I've been dealing with machine I have for so long that it's a miracal to actually come up with some descent paint jobs. (Thank goodness for masking tape). I had the suspicion that too much psi was causing my problems and I certainly appreciate the good advice. Heading to NOLA tomorrow to find me a new toy for my best hobby.
Posted by Anonymous on Tuesday, May 25, 2004 8:44 AM
Tommy, I agree with Scott. Go to your local Home Depot or auto parts store and look for a regulator made by the Campbell Hausfeld Co. They also sell filters, air tanks, fittings and fitting kits for air compressors that are inexpensive (around twenty bucks). My Home Depot had a better selection of fittings than the auto store, but both were priced about the same. Good luck, Scat
Posted by Anonymous on Saturday, May 29, 2004 9:55 AM
Thank you Scat
I'll check the Home Depot today to see if they have anything I can use to help me. Thanks for the info.
Tommy
