- Member since
Posted by Jeeves
on Thursday, May 20, 2004 7:46 AM
- Member since
Posted by Jeeves
on Thursday, May 20, 2004 11:07 AM
One more question...
I will endeavor to paint up the top side tomorrow in olive drab on my Airacobra and was wondering which brand of OD would be best for a beat-up second hand P-39?? I bought the Tamiya OD, but it seems a bit too green (not faded, in other words) to use....any tips on something else closer to that- or should I just beat it up with some chalk?
- Member since
Posted by Anonymous
on Thursday, May 20, 2004 9:32 PM
try adding black
Oh mike, i was always wondering if you could put a sidefeed cup or a custom one to the 360 and use it as that...
- Member since
Posted by MikeV
on Thursday, May 20, 2004 10:08 PM
I don't know of anyone who has done that. Why would you want a side-feed?
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
- Member since
Posted by MikeV
on Thursday, May 20, 2004 10:10 PM
QUOTE: Originally posted by Jeeves
Sorry...just one more thing here for clarification's sake....when you say comes in contact with-- you mean basically, the needle must come through and fill the space at the nozzle end, right? That was dumb of me...of course it would- because otherwise when you depress the trigger, paint would come out if the needle wasn't all the way in, right? I imagine after a few uses. all this timidness on my part will disappear, right?
Yes, you are correct and yes, you will get less timid as you become accustomed to using it.
- Member since
Posted by Jeeves
on Thursday, May 20, 2004 10:11 PM
OK... I am having some trouble trying to find the Needle Juice.. where is it available?? Also-- I am in need of a proper airbrush cleaning container and am open to suggestions... thanks!
- Member since
November 2003
I suppose I am the only one that twirls the needle as it goes into the airbrush until it seats in the nozzle. Twirling the tip helps the softer nozzle mate together with a good seal and you run less of a chance of ramming the needle into the nozzle and "mushrooming" the nozzle.
If you run out of exotically priced airbrush lubricant then a cooking oil in the kitchen works just as well.
Winners never quit; quitters never win.
- Member since
Posted by MikeV
on Friday, May 21, 2004 7:26 AM
QUOTE: Originally posted by roosterfish
I suppose I am the only one that twirls the needle as it goes into the airbrush until it seats in the nozzle. |
No, I do that also.
I would be careful with oils like that as it is possible for them to affect the paint going over them. I wouldn't consider Needle Juice as "exotically priced" either as it retails for $4.30 for a 1 ounce bottle which will last a long time.
Jeeves,
WebAirbrushes.com has it:
http://www.webairbrushes.com/store/detail.cfm?id=262&categoryid=62&path=14%7CAccessories%7C62%7CMiscellaneous%20Accessories%20%7C
- Member since
Posted by Jeeves
on Friday, May 21, 2004 8:18 AM
Thanks Mike!! I do have one more big art store to check in the city of Saratoga that might have it, but it's good to have a link....Great Models lists it as well-- but of course, it's not in stock
- Member since
Posted by MikeV
on Friday, May 21, 2004 7:54 PM
Jeeves,
Medea also makes a good one called, "Super Lube" and if the art stores have it then just buy it. It is pretty much the same thing and would save you the hassle of buying it online and paying as much for shipping as the product.
PS Don't confuse Medea's Super Lube with the one they sell in automotive stores with the same name. It is NOT the same thing!
- Member since
January 2004
Posted by MusicCity
on Saturday, May 22, 2004 6:59 AM
Swanny has one made from a Cool Whip container shown on his web site at http://www.swannysmodels.com/FumeCan.html
I just used an old coffee can (the plastic ones work best since they don't rust). Drilled a ring of holes around the bottom and covered wht inside of them with coffee filters. Then put a couple of old sponges in the can. It doesn't do much for fumes, but it catches the spray particles.
More great sites from Kalmbach Media
