Questions on future and dullcoat use
Posted by Anonymous on Friday, May 21, 2004 6:24 PM
Hello all,
I am new to the forum and I started getting back into modeling two years ago. I have several questions. I've read on the forum that you need to apply future to flat finishes before applying your decals. 1. Do you thin it and if so what should I use? 2. How many coats should I put on? 3. After the decals are put on do I respray the entire model with future, or do I spray Testors dullcoat on to get back to the flat finish look? 4. I painted the model with Testors enamal paints. Any advice would be appreciated.
Thanks,
Scat
    July 2003
Posted by Foster7155 on Friday, May 21, 2004 6:45 PM
I usually put on 2 coats of Future, unthinned, to the entire model and let it set up for at least 24 hours before putting on decals. After the decals have completely dried, another 12 to 24 hours, I again put on one more coat of Future, usually only over the decals themselves, and let this dry. Then I apply my washes. After any touch-ups and the washes are dry, it's time for the Dullcoat, or any flat clear coating, to prep the surface for drybrushing and pastel weathering.
Welcome to the forum and hope this helps,
Robert
Robert Foster
Pensacola Modeleers
    January 2003
Posted by shermanfreak on Friday, May 21, 2004 7:01 PM
Welcome to FSM Don.
I do mine slightly different than Robert.
1. I don't thin Future, just spray it straight from the bottle.
2. I usually only use 1 coat before applying the decals.
3. After the decals have had at least 24 hours to fully set, then I go straight to a dullcote.
Best thing is to try a couple of different methods until you achieve the results that you want.
Enjoy the forums !!!!!
Posted by Swanny on Friday, May 21, 2004 7:23 PM
Welcome back to the hobby and welcome to the forum.
Perhaps you should see "The Complete Future"
http://www.swannysmodels.com/TheCompleteFuture.html
Posted by Anonymous on Friday, May 21, 2004 8:39 PM
Foster, Shermanfreak and Swanny,
Thanks for the great advice and welcome greetings. I now have a better idea of how to try this out. First Im going to check out the web sites you included.
Thanks again,
Scat
