wash formula
wash formula
Posted by Anonymous on Friday, May 28, 2004 7:34 PM
Whenever I use a wash with enamels, it only works great for the first few minutes, then it stops flowing in recesses. Do I have to keep adding thinner?
I'd appreciate the best formula for wash.
Thanks, greg
    July 2003
Posted by saltydog on Friday, May 28, 2004 8:52 PM
greg, when i do washes i use artist's oils and mineral spirits mixed to a strong coffee look. everytime i load my brush, i stirr the brew making sure to rake the bottom of the container over a couple of times to awaken any pigment that has slipped to the bottom. i dont know about enamels, but artist's oils go to the bottom quickly so you may have to stir every time you load the brush like i have to. also, the wash has to be very thin so if its not flowing properly you may want to try adding some more thinner like you mentioned. if that doesnt help, post some of your results and somebody on here will get to the bottom of it for you.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by ipms40049 on Sunday, May 30, 2004 4:05 AM
Hey Greg! try using a acrylic wash, thinned down good, like 50 parts denatured alcohol to 1 or two parts paint. SEE MY POST WITH THE PROBLEM IM HAVING.
mix a little black in with some brown for a good panel line color.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by Anonymous on Tuesday, June 1, 2004 9:33 AM
Thanks for the advice!
Posted by Anonymous on Saturday, June 12, 2004 7:36 AM
I've had excellent results using a "Sludge Wash" fully described in an article called "Quick & Easy Weathering" in the November 2001 issue of FineScale Modeler. However, as I learned recently to my sorrow, the sludge mixture needs to be Fresh! I recently used some that I had laying around for a couple of months and, even tho I mixed it very well, it dried to fast and wouldn't come off. Had to repaint and start over.
____________________________
Wayne Fischer
    August 2003
Posted by tweety1 on Saturday, June 12, 2004 8:13 AM
With washes you have to remember to use the opposing paint type.
If your model is finished with acrylic paints, then use enamel or oil based washes.
And vice versa.
Remember to make your wash up so it resembles dirty thinners.
It's easier to add more colour, then to remove, so dont over do it.
If your wash isn't flowing, then it is either to thick, or the surface tension of the wash is to great.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by mass tactical on Saturday, June 12, 2004 8:42 AM
Greg: I have had good luck with artist's acrylics (tube type) thinned with distilled water with a little dishwashing soap (Dawn) aka sludge wash. Regardless of the type of wash you are using, the surface must have a well cured gloss coat (Future). I leave the wash on just long enough for it to dry--just a few minutes-and then wipe it off. Swanny has an excellent article on this technique on his web site for reference.
Mike McShea
