QUOTE: Since he has a Badger 150 I don' t think he can do it my way as the needle is not exposed enough to get to with your fingernails. The Q-tip would be a better idea. |
Depends on how sharp his claws are
QUOTE: I think this may be the most important thing in relation to his problem.
While 6" seems fairly close it is actually pretty far away for acrylics through an airbrush.
I would spray at about 3" away and see how that does |
That's kind of what I was thinking to. I usually spray from 3 - 4"
BTW, something else you might try. I hadn't used PolyScale (acrylic) paint until just a little while ago. I don't think I really like the paint that much, the coverage isn't great and it takes several coats to get it opaqe, but it will spray by just breathing on it and it takes several minutes to dry.
I've got my regulator so far down that the gauge doesn't even register and there is just a whisper of air coming through the airbrush (and my airbrush is a siphon feed Omni 3000!). I was having terrible "Dry Tip" problems at first, but kept dropping the pressure and it kept getting better.
As per the instructions on the bottle, it's thinned with just distilled water and no retarder. The coverage problem could also be because I thinned it a little too much. I need to learn to read the WHOLE paragraph and not just the part that says "Thin with water". I missed the "10% - 15% water" and thinned it about 30%.
