Ammo For MikeV
    January 2004
Ammo For MikeV
Posted by MusicCity on Sunday, May 30, 2004 4:20 PM
Here ya go Mike ... more ammo for not cleaning your airbrush every time it's used (as I tend to doCool [8D]).
You know the trigger spring in the Omni series? Those little suckers will bounce a ton when you drop them on a concrete floor. I picked up the needle chuck to put a little lube on it and never thought about the spring until I felt it hit me on the ankle. Took me half an hour to find the thing.
    July 2003
Posted by saltydog on Sunday, May 30, 2004 5:15 PM
WOW, that was a close one scott!!!
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    January 2004
Posted by MusicCity on Sunday, May 30, 2004 6:18 PM
Yeah, tell me about it! Painting camo and the only store in town that might have them closed today and tomorrow! I was fixing to start hunting for the old-style ballpoint pens with the springs in them. Not sure if it would have worked, but not having a spring sure wouldn't have.
Posted by MikeV on Sunday, May 30, 2004 8:04 PM
Scott,
Which spring are you talking about?
Do you mean the one in the rear assembly or the one in the air valve?
I am trying to visualze how they fell out? Confused [%-)]
    January 2004
Posted by MusicCity on Sunday, May 30, 2004 8:57 PM
It's the "Back Spring", part number T611 on this drawing: http://www.badgerairbrush.com/omni%20parts.htm
It fits over the "Needle Tube" and I forgot about it being there when I picked up the needle tube.
It didn't fall out, I took it out. When I thoroughly clean my airbrush all of the guts come out. I like to put a little needle lube on the pivot points and the lever that leans against the trigger.
Posted by MikeV on Sunday, May 30, 2004 9:14 PM
I see.
That would be difficult to airbrush without it. Big Smile [:D]
Glad you found it and hopefully learned your lesson. Tongue [:P]
    January 2004
Posted by MusicCity on Sunday, May 30, 2004 9:21 PM
QUOTE: That would be difficult to airbrush without it. Big Smile [:D]
Like I told Chris, I was fixing to start scrounging an old ball point pen with a spring in it Smile [:)]
QUOTE: Glad you found it and hopefully learned your lesson. Tongue [:P]
I am WAY to hard headed to learn a lesson that easily. After all, I found it so the lesson was immediately forgottenCool [8D]. Besides, if it was that easy my basement wouldn't have tiny little model parts scattered all over it. I keep holding them with tweezers, knowing full well that the spring action of a pair of tweezers can launch them into the next county.
