QUOTE:
I am using tamiya acrylic paints for both painting and washing, and everytime i try an washing technic I end up rubbing off the base paint as well (I did give few days for paint to dry before trying wash)...is it a bad idea to use same paint for both painting and washing? or am I doing something wrong?
I agree with ShermanFreak. Be sure to put a barrier coat between your paint coats and wash. Some Tamiya colors are very bad about dissolving lower coats. I finally quit using Tamiya flat black because anything I painted over it would dissolve it. Other than that I really like Tamiya paints.
QUOTE:
I use PUMA air brush and I have very hard time cleaning it up after use. I can't never get it clean enough and each time I try to use it previous paint that I couldn't get to mixs with new paint. So the question is how do you go about cleaning your air brush (advice) or what is some easy cleaning air brush that is recommened?
I'm not familiar with your airbrush, so the best advice I can give is to refer to the manufacturer's recommendations.
I usually spray some of MikeV's magic thinner (2 parts distilled water, 1 part Simple Green, 1 part Windex) through mine and it cleans them just fine. If the paint isn't dry in the brush, just plain water will usually clean it out.
If paint has dried in the nozzle you may be able to soak it in laquer thinner overnight and clean it out.
WARNING! Not being familiar with your airbrush I can't say that laquer thinner won't hurt it! If it has plastic parts or O-rings or gaskets that are not "Thinner Proof" don't use laquer thinner. Also do not soak the air valve as they may have rubber o-rings. Again, refer to the manufacturer's instructions to see what is safe and what isn't.
