Does Tamiya clear paints need thining when using on a airbrush??
Posted by Anonymous on Monday, June 7, 2004 9:18 PM
Hi guys, i am about to airbrush with tamiya clear paints (smoke, clear blue, clear yellow ........ ), and i was wondering if they require any thining or not.
This question also applies to the tamiya dull coat. I want to know if the dull coat is ready to go, or not.
    July 2003
Posted by saltydog on Monday, June 7, 2004 9:38 PM
warmachine, i thin my just a hair. it seems to do alot better than not thinning them. you can always build up the coat to what your looking for but never can you reverse an orange peel effect unless you go through some messy stripping and ruining the paint job around the area. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    January 2004
Posted by MusicCity on Monday, June 7, 2004 9:45 PM
Sign - Ditto [#ditto]
It will spray out of the bottle, but I don't want to use that much pressure so I thin it. It takes a few coats to get good coverage, but it doesn't have a lot of color to it anyway.
I haven't used the dull coat so I can't help you there. Someone will, I'm sure.
Posted by Anonymous on Monday, June 7, 2004 10:20 PM
Thin just a bit, but for Tamiya Clear flat, remember to add a lot of future, 1:3 for dead flat, 1:5 for flat, 1:7 for satin, and then thin just a bit
