curing time...
    November 2003
curing time...
Posted by shrikes on Tuesday, June 8, 2004 10:12 PM
Okay, this is a newbie question, and I've probably seen the answer somewhere here before, so bear with me... Tongue [:P]
I was just wondering what the minimum curing time for for rattlecan painted models is before you can do one of two things: spray on another coat, and safely hold it without the risk of leaving fingerprints?
thanks guys. Big Smile [:D]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    January 2004
Posted by MusicCity on Wednesday, June 9, 2004 5:33 AM
I assume you mean enamels or laquers in rattle cans.
Check the label since some are fast drying and some aren't. Rule of thumb is about 24 hours, but I've sprayed second coats in a couple of hours when I'm in a hurry. Best thing to do is smell it. If you can still smell the thinner in the paint it hasn't cured yet.
Posted by Anonymous on Wednesday, June 9, 2004 12:00 PM
I'm with Scott. If I'm applying extra coats, I wait anywhere from 15 minutes to a couple of hours. If it's a laquer, it'll probably 'flash' pretty quick and extra coats can go on quicker.
For 'handling', I usually wait at least a few days. My impatience sometimes get's the best of me, and when that happens, I often end up with a fingerprint or a dent of some sort in the paint. If you're doing any polishing, definitely wait until the paint is fully cured. Scott's 'smell-test' is what I use, and it's the best one I've found yet. Note that some colors seem to take longer than others to cure. Silver seems to take a really long time... (I had one that took 3 weeks before I couldn't smell it anymore...)
Murray
    January 2004
Posted by knight667 on Wednesday, June 9, 2004 12:05 PM
24-48 hours, like others have said. Patience is one of those things that comes and goes with models...depends on the project. :)
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
