Tamiya Flat Base
Tamiya Flat Base
Posted by Anonymous on Tuesday, June 15, 2004 1:07 AM
I am building RX-78-2 ver KA right now, I am consider myself as beginner, still exparimenting with preshading techniques.
I tried to use the Tamiya Flat Base X-21 (mix with little bit thinner) and air brush it over. I thought it was a layer of clear flat, but it turns out to be white and powdery after it dried. I can even rub it off with my finger over the model. What did I done wrong?
is the FlatBase not supposed to mix with thinner? can I mix colour with some
Flatbase to convert the paint to flat-based?
    July 2003
Posted by saltydog on Tuesday, June 15, 2004 1:26 AM
yes, tamiya flat base is intended to be mixed in with other acrylic colors that may have a gloss or semi gloss sheen to them to make them a flat color. i hear you can mix it with future to make a semi-gloss or satin sheen as well but i've never tried it. as you have already found out, dont airbrush it by itself. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Tuesday, June 15, 2004 1:54 AM
Is this stuff supposed to be pretty thick or did I just get a bad jar?
    August 2003
Posted by South Aussie on Tuesday, June 15, 2004 3:37 AM
As saltydog said, Tamyia Flat base is designed to be added to other acrylic paints to help flatten them and not used by itself.
caseyn5. The jar I have is also a liitle thicker than the normal acrylic so I would say your jars ok, but to be sure I would test it before using it on a model.
Wayne I enjoy getting older, especially when I consider the alternative.
    August 2003
Posted by tweety1 on Tuesday, June 15, 2004 4:06 AM
It is supposed to be thicker than acrylics, it's an additive.
I strongly recommend testing with this stuff, cause to much will appear ok until it dries, then it will look pretty cruddy.
I tried it just yesterday mixed with a little Pledge One Go (Future to you guys)
Works a treat!!!!
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by Anonymous on Tuesday, June 15, 2004 1:06 PM
Ok cool, for a moment I thought I had gotten a raw deal.
Posted by Anonymous on Wednesday, June 16, 2004 12:29 AM
I use Tamiya Flat Base mixed with Future in place of dullcoat because & don't like to spray stuff out of cans & don't like messing with thick laquers. There was an article in FSM a few months back titled "Future - the modeler's best friend" back in the March 2004 issue. It talked briefly about mixing your own flat clear coats. I just check & it's not available to read online, though there are websites like Swanny's that talk about mixing flat base & future...
http://www.swannysmodels.com/TheCompleteFuture.html
It gives me a great finish everytime & neat thing too is that you can customize just how flat/dull you want it to be with the mixing ratio that you use.
Brian
